TurtleP95
Fresh Install: Cannot Update
Wed Mar 25, 2020 9:57 pm
I just did a fresh install of Raspbian Lite on my Pi 4B. I set up my WiFi correctly and everything, although no matter what I try, I get the following message:
[email protected]:~ $ sudo apt update
Ign:1 http://archive.raspberrypi.org/debian buster InRelease
Ign:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Err:3 http://archive.raspberrypi.org/debian buster Release
  404  Not Found [IP: 93.93.135.117 80]
Err:4 http://raspbian.raspberrypi.org/raspbian buster Release
  404  Not Found [IP: 93.93.128.193 80]
Reading package lists... Done
E: The repository 'http://archive.raspberrypi.org/debian buster Release' no longer has a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://raspbian.raspberrypi.org/raspbian buster Release' no longer has a Release file.
My resolv.conf looks like this, if it matters:
[email protected]:~ $ cat /etc/resolv.conf
# Generated by resolvconf
domain lan
nameserver 192.168.86.1
Any help would be greatly appreciated!
pcmanbob
Re: Fresh Install: Cannot Update
Thu Mar 26, 2020 11:32 am
Hi.
You might find that the server you were connecting to was in the process of being updated , I would suggest trying the sudo apt update command again to see if it works now.
TurtleP95
Thu Mar 26, 2020 5:34 pm
I ran sudo apt update just now, but it still comes up with the same error.
davidcoton
Thu Mar 26, 2020 9:27 pm
Is the Pi's clock set correctly? Updates will error if tried immediately after boot, before the clock has synchronised with a timeserver.
Not sure if that is the same error message, though.
Signature retired
TurtleP95
Fri Mar 27, 2020 4:04 pm
timedatectl reports the System Clock is not synchronized. I did try to set it manually the other day to fix potential time issues, but that didn't help.
pcmanbob
Sat Mar 28, 2020 11:54 am
What happens if you try to ping the 2 servers.
like this
ping -c5 93.93.135.117
ping -c5 93.93.128.193
You can also temperately set the date/time with this command , it will also prove you have a working internet connection
sudo date -s "$(wget -qSO- --max-redirect=0 google.com 2>&1 | grep Date: | cut -d' ' -f5-8)Z"
TurtleP95
Sat Mar 28, 2020 5:56 pm
I decided to do another fresh install to see if that fixes it. It's now .. stuck(?) on Started Update UTMP about System Runlevel Changes.
pcmanbob
Sat Mar 28, 2020 6:10 pm
Then this suggests one of the following may actually be the cause of your problems.
1. Bad or corrupted image download
2. Card reader is not fully compliant with the SD card type you are using
3. SD card is going bad or is a fake
4. Image not being written to card correctly
TurtleP95
Sat Mar 28, 2020 6:13 pm
My bad, turns out it was fine. It just wanted me to log in but never updated to show that it wanted the username.
Pinging the IP addresses it says 'Destination Host Unreachable'
pcmanbob
Sat Mar 28, 2020 6:37 pm
So what do you get if you run these pings
ping -c5 8.8.8.8
ping -c5 google.com
If things still aren't running smoothly and as expected may be it is one of the problems I suggested.
TurtleP95
Sat Mar 28, 2020 7:44 pm
ping -c5 8.8.8.8
ping -c5 google.com
[email protected]:~ $ ping -c5 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
From 192.168.86.1 icmp_seq=1 Destination Host Unreachable
From 192.168.86.1 icmp_seq=2 Destination Host Unreachable
From 192.168.86.1 icmp_seq=3 Destination Host Unreachable
From 192.168.86.1 icmp_seq=4 Destination Host Unreachable
From 192.168.86.1 icmp_seq=5 Destination Host Unreachable
--- 8.8.8.8 ping statistics ---
5 packets transmitted, 0 received, +5 errors, 100% packet loss, time 10ms
[email protected]:~ $ ping -c5 google.com
PING google.com (172.217.12.174) 56(84) bytes of data.
From testwifi.here (192.168.86.1) icmp_seq=1 Destination Host Unreachable
From testwifi.here (192.168.86.1) icmp_seq=2 Destination Host Unreachable
From testwifi.here (192.168.86.1) icmp_seq=3 Destination Host Unreachable
From testwifi.here (192.168.86.1) icmp_seq=4 Destination Host Unreachable
From testwifi.here (192.168.86.1) icmp_seq=5 Destination Host Unreachable
--- google.com ping statistics ---
I don't think it's any of the things you mentioned. The SD card has always worked on DietPi and I'm certain the download was not corrupt when I flashed it to the SD.
pcmanbob
Sat Mar 28, 2020 8:04 pm
From the results of the last lot of pings you either don't have the pi connected to your network or your network is not forwarding your pi's request to the internet.
Please post the results of
 ifconfig
TurtleP95
Sat Mar 28, 2020 8:06 pm
 ifconfig
[email protected]:~ $ ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether dc:a6:32:14:4f:df  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.86.35  netmask 255.255.255.0  broadcast 192.168.86.255
        inet6 fe80::cc70:64eb:8fe9:c476  prefixlen 64  scopeid 0x20<link>
        ether dc:a6:32:14:4f:e0  txqueuelen 1000  (Ethernet)
        RX packets 14199  bytes 3266214 (3.1 MiB)
        TX packets 544  bytes 74065 (72.3 KiB)
I'm able to SSH into the Pi, if that helps.
Sat Mar 28, 2020 8:07 pm
Your network is not connected to the public internet.
How do you have it wired or what WiFi are you using?
This is a doctor free zone.
TurtleP95
Sat Mar 28, 2020 8:43 pm
It should be connected. I'm connected via WiFi at home.
The router is connected to a Google WiFi mesh hub, though I don't think that should be an issue.
pcmanbob
Sat Mar 28, 2020 8:50 pm
Well the ping results show it is not, do you have another pc connected to the same network and can that access web sites.
TurtleP95
Sat Mar 28, 2020 8:57 pm
Of course. I'm on my desktop right now.
pcmanbob
Sat Mar 28, 2020 9:03 pm
Is it connected via the same WiFi as the pi ?
What's the PC's IP address ?
evilbyte
Sat Mar 28, 2020 9:17 pm
I'm having the same problem. I installed buster version on my new 4B, and getting it to update fails at the same step every time. Tried installing retropie, and that fails also due to the fact that it can't get necessary packages from raspbian.raspberry.org mostly. Tried wi-fi and ethernet, doesn't make a difference. The update always fails tries to get the 69.1MB packages. Gets to 2% from the looks of it and times out. Pinging 93.93.128.193 I see no issues.
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Get:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
Ign:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
Get:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [18.3 MB]
Get:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [69.1 MB]
Err:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
  Connection timed out [IP: 93.93.128.193 80]
Fetched 15.0 kB in 3min 17s (75 B/s)
Building dependency tree
All packages are up to date.
W: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/buster/main/binary-armhf/Packages  Connection timed out [IP: 93.93.128.193 80]
W: Some index files failed to download. They have been ignored, or old ones used instead.
Sat Mar 28, 2020 9:53 pm
Do you have your RPi connected to your router/WiFi access point or are you using something like Windows "Internet Connection Sharing" or a Windows "Mobile Hotspot"?
TurtleP95
Sun Mar 29, 2020 4:19 am
Yes, my Pi and the PC are on the same WiFi network.
Sun Mar 29, 2020 8:53 am
Is your router blocking your RPi from accessing the public internet? Give it a reboot, hit the config page at http://192.168.0.1 http://192.168.1.1 http://192.168.0.254 or http://192.168.1.254 (device dependent).
TurtleP95
Sun Mar 29, 2020 4:25 pm
I don't have access to the router information, someone else does. Even then, I don't think Google's Mesh WiFi stuff automatically blocks anything unknown from reaching the internet.
