pmarct
Wirelessly receive and compile teensy/arduino code
Wed Mar 25, 2020 4:45 pm
So the project consists of two rasberry pis that are connected via wifi through a server-client relationship. One of the pis is connected to a teensy microcontroller and the other pi is strictly used to send commands and new code.
So far I can send and receive data/files between the two pis via Python sockets. However, I need to create a script that receives the new teensy/arduino code file and automatically compiles and uploads it to the teensy via the command line.
I've searched this countless times and haven't found a clear way of doing this, could anyone help or point me in the right direction?
neilgl
Re: Wirelessly receive and compile teensy/arduino code
Wed Mar 25, 2020 5:01 pm
Have you looked at arduino-cli
PiGraham
Wed Mar 25, 2020 5:08 pm
Agreed, use the commandline tool for Arduino, not the IDE.
Then you can send the source file, build it and upload it to the Teensy. all from a shell script or ox.popen calls from Python .
https://github.com/arduino/arduino-cli
To compile the sketch you run the compile command passing the proper FQBN string:
$ arduino-cli compile --fqbn arduino:samd:mkr1000 MyFirstSketch
Sketch uses 9600 bytes (3%) of program storage space. Maximum is 262144 bytes.
To upload the sketch to your board, run the following command, this time also providing the serial port where the board is connected:
$ arduino-cli upload -p /dev/ttyACM0 --fqbn arduino:samd:mkr1000 MyFirstSketch
pmarct
Wed Apr 01, 2020 4:01 pm
Can you use arduino cli for teensy? I am using a 4.0 and I don't even think teensy cli supports the 4.0 yet
PiGraham
Fri Apr 03, 2020 10:13 am
I don't know. Have you tried?
It's a Teensy issue so you could try the Teensy forums.
Return to “Advanced users”
