Garvan
how to exit signal.pause() in code [SOLVED]
Wed Mar 25, 2020 1:18 pm
The BlueDot documentation https://bluedot.readthedocs.io/en/latest/recipes.html uses pause() to pause program flow while threads are waiting for signals. You can "exit" pause() by pressing Ctrl-C to terminate the program. How do I cause pause() to exit in code? For example, if I want a double-press to clean-up and exit the program.
An example of the use of pause()
from bluedot import BlueDot
from signal import pause
def say_hello():
    print("Hello World")
def say_bye():
    print("Exit")
bd = BlueDot()
bd.when_pressed = say_hello
bd.when_double_pressed = say_bye
pause()
B.Goode
Re: how to exit signal.pause() in code
Wed Mar 25, 2020 1:36 pm
Documentation for the library you are using is here: https://docs.python.org/3/library/signal.html
Depending on the behaviour you want, maybe sigtimedwait() is what you need.
If this is just for cleanup at the end of the script do you need to take any particular action?
Garvan
Wed Mar 25, 2020 2:32 pm
I want to exit the program when a button is pressed in BlueDot. Is there a way to exit signal.pause()? Or an alternative to signal.pause()?
I can exit the program using Ctrl-C, but I will not have a keyboard attached in the finished project.
scotty101
Wed Mar 25, 2020 2:45 pm
You could just have a small while loop with a time.sleep in it.
running = True
def say_bye():
    global running
    print("Exit")
    running = False
while running:
    time.sleep(0.1)
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
Garvan
Wed Mar 25, 2020 3:06 pm
running = True
def say_bye():
    global running
    print("Exit")
    running = False
while running:
    time.sleep(0.1)
Thanks, I will try this.
RobCranfill
Contact: Website YouTube
Re: how to exit signal.pause() in code [SOLVED]
Sun May 24, 2020 12:02 am
I see that someone - the OP? - marked this as "[SOLVED]", but at best what I see here is a workaround. Does anyone know how to actually solve it? I have the same problem.
I have a headless Pi running some software for a MIDI project of mine. I attached a button (to GPIO pin 7) so that I can issue a shutdown command so as to take the system down nicely. When running for real, the shutdown command kills the program, fine, but when I run in test mode (see below) I *have* to <ctrl>C the program, I can't just exit nicely. (Which is OK, but bugs me.)
Anyone have a real solution?
#!/usr/bin/env python3
# Wait for GPIO pin 7 to get grounded, then shut the machine down.
# args: [--test]
from datetime import datetime
from gpiozero import Button
import os
import signal
import sys
import time
testing_ = False
if len(sys.argv) == 2 and sys.argv[1] == '--test':
  testing_ = True
  print('Setting test mode')
def doShutdown():
  msg = '{} POWERING OFF! at {}'.format(sys.argv[0], datetime.now())
  if testing_:
    msg = '(Testing) ' + msg
  os.system('sudo logger -p emerg "{}"'.format(msg))
  if testing_:
    print('Testing - NOT shutting down')
# why doesn't this work?
#    sys.exit(1)
    print('You have to hit <ctrl>C, I don''t know why!')
  else:
    os.system('sudo poweroff')
button = Button(7)
button.when_held = doShutdown
print('Waiting for button hold....')
# This waits, but we can't get out of it - sys.exit() doesn't!
# But it's OK in our real world use, cuz the poweroff command *does* kill everything.
signal.pause()
RobCranfill
Sun May 24, 2020 12:32 am
OK, I think I found the answer. According to the docs https://docs.python.org/3/library/signal.html
signal.pause()
Cause the process to sleep until a signal is received; the appropriate handler will then be called. Returns nothing.
So all you have to do is ... send yourself a signal. You don't even really need to do anything with it, just receiving the signal seems to break out of signal.pause().
Here's a somewhat-minimal example:
# Minimal example of how to break out of signal.pause().
# This waits for a GPIO button to be held (for 1 second), and then exits.
# @see https://docs.python.org/3/library/signal.html
# [email protected]
import os
import signal
import sys
# Handler for SIGUSER1
def handleSignal(num, stack):
  print('Got signal! And now we mysteriously will exit....')
def doShutdown():
  print('In Button.when_held handler...')
  # If this worked, all I really want is this. Or return, or whatever. Done.
  #  Why doesn't this work?
#  sys.exit(1)
  # Send a SIGUSER1; this seems to cause signal.pause() to return.
  os.kill(os.getpid(), signal.SIGUSR1)
button = Button(7)
# Install a handler for SIGUSER1 .... which seems to entirly fix our problem. Why?!?!
signal.signal(signal.SIGUSR1, handleSignal)
# This waits.
# According to the docs,
#  "Cause the process to sleep until a signal is received; the appropriate handler will then be called."
# so I guess this makes sense.
signal.pause()
RobCranfill
Sun May 24, 2020 12:44 am
One final comment: If you want to do even less coding, you don't really need to define and hook up a handler for the signal. Just send it, and signal.pause() still exits. In my test code, above, I did that and it works, but I do get a message on screen that
User defined signal 1
was received.
/rob
Return to “Python”
