Kanna
help me i am getting output always zero only
Wed Mar 25, 2020 8:18 am
i am trying read moisture value but
i am always getting output zero
help me out
import os
import sys
import spidev
import RPi.GPIO as GPIO
import httplib
import urllib2
import time
GPIO.setmode(GPIO.BCM)
# Open up SPI bus
spi = spidev.SpiDev()
spi.open(0,1)
SoilSensor=5
#Declare API Key
apikey = '92L7QM03PXTZU0B2'
def getReading(channel):
    # Get Raw Data from chip
    rawData = spi.xfer([1, (8 + channel) << 4, 0])
    # Process Data to Understandable
    processedData = ((rawData[1]&3) <<8) + rawData[2]
    return processedData
def convertVoltage(bitValue, decimalPlaces=2):
    voltage = (bitValue * 3.3) / float(1023)
    voltage = round(voltage, decimalPlaces)
    return voltage
def main():
    print("sustem ready")
    URL="https://api.thingspeak.com/update?api_key=%s"%apikey
    print("wait")
    while True:
        SoilData = getReading(SoilSensor)
        SoilVoltage = convertVoltage(SoilData)
        finalurl=URL+'&field3=%s&field4=%s'%(SoilData,SoilVoltage)
        print(finalurl)
        s=urllib2.urlopen(finalurl);
        #Print Values
            print("Soil Moisture bitValue = {} ; Voltage = {} V".format(SoilData, SoilVoltage))
            s.close()
        time.sleep(10)
if __name__=='__main__':
     main()
Webp.net-compress-image (2).jpg (139.93 KiB) Viewed 526 times
B.Goode
Re: help me i am getting output always zero only
Wed Mar 25, 2020 8:26 am
Seriously?
If you hope to get help from the volunteer helpers in these forums some facts would be useful!
What model of RPi board?
What Operating System is it running?
What specific sensor?
How is it wired to your RPi? (A clear, focused, detailed photo of the cabling would be useful.)
pcmanbob
Wed Mar 25, 2020 9:23 am
The first this is you are missing the spi.max_speed line in your program.
# Open up SPI bus
spi.open(0,1)
spi.max_speed_hz=1000000
you need to add it like this.
If you still get a zero result then you need to give us more information as @B.Goode suggested above.
Kanna
Thu Mar 26, 2020 6:24 am
i added the new line but still there is no change in output
i am using raspberry pi 3 model
soilmoisture sensor
vcc=pin 2
gnd=pin 39
d0=pin 29(gpio 5)
i used following commands in terminal
enabled spidev
sudo apt-get install git python-dev
git clone git://github.com/doceme/py-spidev
cd py-spidev/
sudo python setup.py install
sudo apt-get install python-numpy
bensimmo
Thu Mar 26, 2020 7:59 am
You have nothing wired up to SPI?
Just 5V and Ground and a random Gpio pin.
A link to the product you have bought, there are probably many soil moisture sensors.
B.Goode
Thu Mar 26, 2020 10:40 am
soilmoisture sensor
vcc=pin 2
gnd=pin 39
d0=pin 29(gpio 5)
enabled spidev
cd py-spidev/
I tried to help by suggesting a list of facts that might be relevant to volunteer helpers able to assist. Time is too precious at the moment to be playing guessing games. I am withdrawing from the discussion.
pcmanbob
Thu Mar 26, 2020 11:02 am
vcc=pin 2
gnd=pin 39
d0=pin 29(gpio 5)
Well you should not be powering your sensor with 5V unless it specifically says that the output will be 3V when powered by 5V,
and you don't have a sensor that supports SPI by the look of it as you would have 4 data connections as well as VCC/ground.
Please post a link to the sensor you have, if you want people to be able to help you.
Kanna
Wed Apr 01, 2020 8:48 am
i dont have link of the product but
i am uploading the sensor image which i am using
Webp.net-compress-image (3).jpg (177.39 KiB) Viewed 348 times
bensimmo
Wed Apr 01, 2020 8:55 am
There sensor works by sending on/off on the DO wire to you Gpio.
That is it, you get no data from it, it acts like a switch.
You set the setpoint (point that it gives on/off) with the blue square/white circle variable resistor.
For that look at using Gpiozero and a button, as they are similar.
Kanna
Wed Apr 01, 2020 9:40 am
as per the sensor i am using it has both analog and digital outputs
The Analogue output gives a variable voltage reading that allows you to estimate the moisture content of the soil (using some maths!). The digital output gives you a simple "on" or "off" when the soil moisture content is above a certain value. The value can be set or calibrated using an adjustable on board potentiometer. In this case, we just want to know either "Yes, the plant has enough water" or "No, the plant needs watering!", so we'll be using the digital out. We'll set this value later at which you want the sensor to "trigger" a notification.
in order to get values i have to use analog pin but raspberry pi is only having digital pins so i have to use ADC
thank for ur suggestions
davidcoton
Wed Apr 01, 2020 10:00 am
You need to initialise pin 5 with a pull-up.
Signature retired
pcmanbob
Wed Apr 01, 2020 10:02 am
To read analogue output of your sensor you need to connect it to the MCP3008 like this.
NOTE... you need to use the AO output.
you can then use this code to read the voltage value from the MCP3008
#!/usr/bin/python
import spidev
import time
import sys
spi = spidev.SpiDev()  # create spi object
spi.open(0, 0)  # open spi port 0, device (CS) 0, for the MCP8008
def readadc(adcnum):  # read out the ADC
    if ((adcnum > 7) or (adcnum < 0)):
        return -1
    r = spi.xfer2([1, (8 + adcnum) << 4, 0])
    adcout = ((r[1] & 3) << 8) + r[2]
    return adcout
while True:
    v = readadc(0) * (3.3 / 1023.0)  # Convert value to voltage
    print v
    time.sleep(1)
bensimmo
Wed Apr 01, 2020 11:55 am
As above, but I would try Gpiozero module again, they have you covered no matter your MCPxxx used
https://gpiozero.readthedocs.io/en/stab ... erters-adc
Kanna
Tue Apr 07, 2020 8:21 am
Anyone suggest me a motor or alternative for smart irrigation purpose
1.product link
2.interfacing code
3.connections
pcmanbob
Tue Apr 07, 2020 9:15 am
1.product link
2.interfacing code
3.connections
A motor to do what ?
