bchairez
openCV project
Wed Mar 25, 2020 4:42 am
Hi guys, so I'm working on a project for school and I am in desperate need of help because I am pretty new to python and using the Raspberry pi. I am entering this command 'sudo python capture-positives.py' and get back these messages:
  File "capture-positives.py", line 14, in <module>
    import hardware
  File "/home/pi/pi-facerec-box-master/hardware.py", line 8, in <module>
    import RPIO
  File "/home/pi/pi-facerec-box-master/RPIO/__init__.py", line 116, in <module>
    from RPIO._RPIO import Interruptor
  File "/home/pi/pi-facerec-box-master/RPIO/_RPIO.py", line 64, in <module>[/i][/i]
    class Interruptor:
  File "/home/pi/pi-facerec-box-master/RPIO/_RPIO.py", line 113, in Interruptor
    pull_up_down=_GPIO.PUD_OFF, threaded_callback=False,
AttributeError: 'module' object has no attribute 'PUD_OFF'
Error in atexit._run_exitfuncs:
  File "/usr/lib/python2.7/atexit.py", line 24, in _run_exitfuncs
    func(*targs, **kargs)
  File "/home/pi/pi-facerec-box-master/RPIO/_RPIO.py", line 58, in exit_handler
    RPIO.stop_waiting_for_interrupts()
AttributeError: 'NoneType' object has no attribute 'stop_waiting_for_interrupts'
Error in sys.exitfunc:
can someone please help, thank you!
Re: openCV project
Wed Mar 25, 2020 1:39 pm
What's "capture-positives.py"? Where did that come from? Who wrote it? Is it a python2 program or a python3 one? Why do you think it needs to run with sudo? Hint: it doesn't.
bchairez
Re: openCV project
Wed Mar 25, 2020 5:22 pm
it came with the project, I downloaded it from 'https://learn.adafruit.com/raspberry-pi ... x/software'. It's an older project so I had to download opencv version 4 while they used 2, and I believe its written in python 2.
bchairez
Re: openCV project
Wed Mar 25, 2020 5:24 pm
https://learn.adafruit.com/raspberry-pi ... x/software is the correct link
Re: openCV project
Wed Mar 25, 2020 11:07 pm
Have you read that BIG RED NOTICE on the first page at https://learn.adafruit.com/raspberry-pi ... x/software
https://learn.adafruit.com/raspberry-pi-face-recognition-treasure-box/software wrote:Note this project was created in 2013 and the Raspberry Pi operating system has since
been updated to not be compatible with the RPIO library mentioned below. Use an older
version of Raspbian like a wheezy release from 2013 from:
http://downloads.raspberrypi.org/raspbian/images/
You are wasting your time trying to get that stuff to run on a modern Raspberry Pi with Raspbian Buster.
bchairez
Re: openCV project
Fri Mar 27, 2020 2:02 am
Yes, I read that which is why i downloaded opencv4 instead.
Return to “Python”
