kaehsu
Keep receiving SIGCHLD when I run shell script on Buster
Wed Mar 25, 2020 3:59 am
Dear all:
I find an interesting situation when I run shell script on Buster.
I create a shell script "traplist.sh" on Stretch to test trap handling:
#!/usr/bin/env bash
trap "echo 'SIGHUP(01) received.'" SIGHUP
trap "echo 'SIGINT(02, Ctrl-C) received.'; exit 1" SIGINT
trap "echo 'SIGQUIT(03) received.'" SIGQUIT
trap "echo 'SIGILL(04) received.'" SIGILL
trap "echo 'SIGTRAP(05) received.'" SIGTRAP
trap "echo 'SIGABRT(06) received.'" SIGABRT
trap "echo 'SIGBUS(07) received.'" SIGBUS
trap "echo 'SIGFPE(08) received.'" SIGFPE
trap "echo 'SIGKILL(09) received.'" SIGKILL
trap "echo 'SIGUSR1(10) received.'" SIGUSR1
trap "echo 'SIGSEGV(11) received.'" SIGSEGV
trap "echo 'SIGUSR2(12) received.'" SIGUSR2
trap "echo 'SIGPIPE(13) received.'" SIGPIPE
trap "echo 'SIGALRM(14) received.'" SIGALRM
trap "echo 'SIGTERM(15) received.'" SIGTERM
trap "echo 'SIGSTKFLT(16) received.'" SIGSTKFLT
trap "echo 'SIGCHLD(17) received.'" SIGCHLD
trap "echo 'SIGCONT(18) received.'" SIGCONT
trap "echo 'SIGSTOP(19) received.'" SIGSTOP
trap "echo 'SIGTSTP(20) received.'" SIGTSTP
trap "echo 'SIGTTIN(21) received.'" SIGTTIN
trap "echo 'SIGTTOU(22) received.'" SIGTTOU
trap "echo 'SIGURG(23) received.'" SIGURG
trap "echo 'SIGXCPU(24) received.'" SIGXCPU
trap "echo 'SIGXFSZ(25) received.'" SIGXFSZ
trap "echo 'SIGVTALRM(26) received.'" SIGVTALRM
trap "echo 'SIGPROF(27) received.'" SIGPROF
trap "echo 'SIGWINCH(28) received.'" SIGWINCH
trap "echo 'SIGIO(29) received.'" SIGIO
trap "echo 'SIGPWR(30) received.'" SIGPWR
trap "echo 'SIGSYS(31) received.'" SIGSYS
trap "echo 'Signal (32) received.'" 32
trap "echo 'Signal (33) received.'" 33
trap "echo 'SIGRTMIN(34) received.'" 34
trap "echo 'SIGRTMIN(35) received.'" 35
trap "echo 'SIGRTMIN(36) received.'" 36
trap "echo 'SIGRTMIN(37) received.'" 37
trap "echo 'SIGRTMIN(38) received.'" 38
trap "echo 'SIGRTMIN(39) received.'" 39
trap "echo 'SIGRTMIN(40) received.'" 40
trap "echo 'SIGRTMIN(41) received.'" 41
trap "echo 'SIGRTMIN(42) received.'" 42
trap "echo 'SIGRTMIN(43) received.'" 43
trap "echo 'SIGRTMIN(44) received.'" 44
trap "echo 'SIGRTMIN(45) received.'" 45
trap "echo 'SIGRTMIN(46) received.'" 46
trap "echo 'SIGRTMIN(47) received.'" 47
trap "echo 'SIGRTMIN(48) received.'" 48
trap "echo 'SIGRTMAX(49) received.'" 49
trap "echo 'SIGRTMAX(50) received.'" 50
trap "echo 'SIGRTMAX(51) received.'" 51
trap "echo 'SIGRTMAX(52) received.'" 52
trap "echo 'SIGRTMAX(53) received.'" 53
trap "echo 'SIGRTMAX(54) received.'" 54
trap "echo 'SIGRTMAX(55) received.'" 55
trap "echo 'SIGRTMAX(56) received.'" 56
trap "echo 'SIGRTMAX(57) received.'" 57
trap "echo 'SIGRTMAX(58) received.'" 58
trap "echo 'SIGRTMAX(59) received.'" 59
trap "echo 'SIGRTMAX(60) received.'" 60
trap "echo 'SIGRTMAX(61) received.'" 61
trap "echo 'SIGRTMAX(62) received.'" 62
trap "echo 'SIGRTMAX(63) received.'" 63
trap "echo 'SIGRTMAX(64) received.'" 64
TIMES=100
while [ $TIMES -gt 0 ]; do
	echo -e "Total $TIMES remained\n"
	TIMES=$((TIMES -1))
	sleep 1
done
When I execute this, I can use "kill" command to send signal to the program and read what signal the program received.
To save my time, I write another program "signalsend.sh" to send the signal automatically:
#!/usr/bin/env bash
SIGN=$1
SSPID=$2
declare -a BYPASS=(2 9 19 32 33)
while [ $SIGN -le 64 ]; do
  [[ ! " ${BYPASS[@]} " =~ " ${SIGN} " ]] && echo "Send signal $SIGN" && kill -$SIGN $SSPID
  SIGN=$((SIGN +1))
  sleep 1
done
Everything goes well when I execute the program on Stretch, please refer the following snapshot:
The interesting things is, when I run the program to Buster, I found traplist.sh will keep receive SIGCHLD:
Does anyone know what happened?
Why the program running on Buster will keep receiving SIGCHLD?
The running environment is most updated by apt on RPi 3B+(Stretch) and RPI 3B+ & 4B(Buster).
Any comment is welcome :-)
Regards
Kae
topguy
Re: Keep receiving SIGCHLD when I run shell script on Buster
Wed Mar 25, 2020 12:46 pm
I have a (very looooose ) theory that the newer versions of bash might run "trap"s in a child process. So when the "trap" is finished you get the SIGCHLD.
I'm not sure if you might get an infinite loop when you get to signal 17.... ;-)
kaehsu
Thu Mar 26, 2020 3:41 am
Yes, it seems when child process is complete & terminated, a SIGCHLD will be sent to the parent process.
Refer the following script:
#!/usr/bin/env bash
function SHOWPID (){
  echo -e "Receiving signal SIGCHLD"
  echo -e "\tThe parent PID is $$; the child PID is $CHILDPID"
trap SHOWPID SIGCHLD
declare -i TIMES=${1:-100}
declare -i SLEEP=${2:-1}
  echo -e "$TIMES times remained."
  TIMES=$((TIMES -1))
  echo "Now suspend for $SLEEP second(s)"
  sleep $SLEEP && echo "Sleep complete, now continue" &
  export CHILDPID=$!
  echo -e "Fork child PID for sleep is $CHILDPID"
  wait && echo -e "Now forked child PID $CHILDPID is terminated.\n"
done
We know bash will fork a child process for sleep.
I found trap will be received before wait, fyi.
Regards
Kae
Return to “Raspbian”
