hotgarbage
unsupported operand type() * generator and float
Wed Mar 25, 2020 3:11 am
Hi, i am stuck at what to do with code has anyone come across this.
from gpiozero import MCP3008
import time
adc = MCP3008(channel=0)
count = 0
values = []
while True:
wind =round(adc.values * 3.3,1)
if not wind in values:
values.append(wind)
count +=1
print(count)
>>%Run wind_direction_byo.py
File "/home/pi/weather-station/wind_direction_byo.py", line 8, in <module>
TypeError: unsupported operand type(s) for *: 'generator' and 'float'
pcmanbob
Re: unsupported operand type() * generator and float
Wed Mar 25, 2020 9:13 am
Edit...
Removed incorrect answer to prevent confusion.
and when using code tags you use them like this
Add [code] at the top
code goes here
and [/code] at the bottom.
scotty101
Wed Mar 25, 2020 9:18 am
That's not it.
Round supports two arguments.
round(...)
    round(number[, ndigits]) -> number
    Round a number to a given precision in decimal digits (default 0 digits).
    This returns an int when called with one argument, otherwise the
    same type as the number. ndigits may be negative.
OP should be doing the following
wind =round(adc.value * 3.3,1)
value not values. values is a generator where as value is the current numerical ADC reading.
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
hotgarbage
Thu Mar 26, 2020 6:51 pm
ok . i see that i have values not value . I have been reading up on code and was getting lost . Thank you for your help. I now have great respect for those that code it has been a trying laguage for me to grasp . :)
Return to “Python”
