TapeStreamer
Which Pi do i need to watch 1080p video from a satellite tuner?
Tue Mar 24, 2020 9:54 pm
Hello there :)
I'm a beginner, so i have Raspian installed on my pc to test it out.
The main thing i want to do with a Pi is to watch my files on my satelite tuner which are .ts files... I already tested to open them with VLC in Debain and it seems to work perfectly on my i4460 with 16 gb ram...
I also want to watch Youtube video on the Pi at 1080p, higher isnt necessary because my tv only supports up to 1080p. (Samsung 50 inch plasma screen from 2010)
I would like to share all my files on the satelite tuner with the Pi, i managed to browse the content of the files, but is there an more easy way to watch them? (like another mediaplayer in Debian)
I wanted to buy the Pi 4 with 4 gb ram, because i had a simple calculation : the more ram, the smoother or faster, but i can imagine that it isnt necessary to buy this model, Pi 3b with 1 gb would be sufficient too?
In other words:
I would like to get tips of what to buy for this purpose
it would be nice to have a gigabyte network speed on the pi, but i think the pi3 only does 10/100? but maybe that is ok for this situation...
So the main goal is to play media files (.ts) from the sat. reciever and play youtube at 1080p connected through hdmi and controlled by a cordless mouse and keyboard.
I also like to know if i really need a cooler for the pi3b and pi4..... i dont want to pay alot of money for this set especially because the pi itself is already very cheap...
thanks for reading and hopefully you, the reader can be so kind enough to help me ;)
neilgl
Re: Which Pi do i need to watch 1080p video from a satellite tuner?
Wed Mar 25, 2020 9:49 am
I would go with a 2GB pi4, no cooler need. Run VLC on that. Some .ts files I have are encrypted HD so it can’t play those.
drgeoff
Wed Mar 25, 2020 10:57 am
.... i have Raspian installed on my pc....
No you do not. https://www.raspberrypi.org/forums/view ... 6&t=217203
And BTW the correct spelling is Raspbian.
Wed Mar 25, 2020 11:15 am
Hello there :)
I'm a beginner, so i have Debian Buster installed on my pc to test it out.
I fixed that for you, what works in x86 Debian Buster on a PC will not necessary work in Raspbian Buster ARMHF running on the Raspberry Pi SBC.
How is the Satellite Tuner connected ???
Retired disgracefully.....
......to an uncomplicated life !
neilgl
Wed Mar 25, 2020 12:51 pm
Certain tuners have firmware with network connectivity so you can ftp files around or use web interface...
TapeStreamer
Wed Mar 25, 2020 1:48 pm
Thanx for the replies... :)
It is connected through an lan i can browse on it very easily with W10...
I can ftp the tuner (enigma2) and see all of the files (openpli) as the files on de hdd, which are all .ts files..
I know i cant compare a i5 with a raspberry but i just wanted to know if the .ts would play and they did...
i've seen that youtube video's are very choppy now on the rp... so i dont know if i buy one just jet...
Wed Mar 25, 2020 1:55 pm
I was not comparing i5 to RPi, I was stating the underlying CPU Architecture.
Regards YouTube and similar then a Raspberry Pi 4B 2GB should suffice if running LibreElec which is a dedicated Multimedia Platform :
https://libreelec.tv/about/
https://kodi.tv/
neilgl
Wed Mar 25, 2020 4:03 pm
As a quick test I played a .ts file (378MB, SD recorded TV show) in VLC 3.0.8 on a pi3 running Raspbian Buster. It worked OK.
TapeStreamer
Thu Mar 26, 2020 9:28 am
Thanx all for the reply, i will look into libreelec and kodi from a test @ etaprime..
@neilgl
could you test the following files? one is a 2 minute video (fta) at hd quality which i recorded this morning
the other file is just 1 minute at uhd quality...
hd: https://drive.google.com/open?id=1sr5Hb ... Zs17fpPdYE
uhd https://drive.google.com/open?id=1Q4uwr ... jloRHTeCWN
neilgl
Thu Mar 26, 2020 9:59 am
Will do
Later, Polperro one looked fine on pi3, playing through chromium. SES one looked blocky at start and dark areas later looked blocky purple/red but that could be my old monitor (HP2310). Otherwise all fine, the F1 race car looked good.
Even later, a new pi4 2GB arrived - videos played OK same as pi3.
TapeStreamer
Thu Mar 26, 2020 2:38 pm
Will do
thank you very much for the test.. :D :P . it os normal that at 1st the quality of the uhd sample is blocky, so it is on a faster pc... it need to be downloaded first and then played with an mediaplayer (vlc for example)
neilgl
Thu Mar 26, 2020 2:40 pm
OK. I could not download and save the file from that google drive, just play it in chromium.
TapeStreamer
Thu Mar 26, 2020 6:29 pm
could you test it tomorrow so i can put up a compressed file (zip or 7zip) so you are able to download it and test it out with 1 new clip?
neilgl
Thu Mar 26, 2020 11:02 pm
OK yes
gkreidl
Fri Mar 27, 2020 4:20 am
UHD in H264 is not possible on any Rpi.
Otherwise I'm watching Sat. TV for many years on all of my RPis, SD and HD. I've got a USB-Sat-Receiver connected to one of my RPis and stream any content into my network, including complete transponders.
Minimal Kiosk Browser (kweb)
TapeStreamer
Fri Mar 27, 2020 7:58 am
What kind of USB-Sat-Receiver do you have? I've got an twin tuner descrambler is oscam...
gkreidl
Fri Mar 27, 2020 8:12 am
My Technisat receiver (single tuner) is not available any more.
neilgl
Fri Mar 27, 2020 10:08 am
OK that H264 video with resolution 1920x1080, 25FPS played perfectly on my new pi4 using VLC.
Some time later I might do a test of the pi4 4K with my Samsung 4K 55 inch TV - as the documentation says it can use "a single display at 4K with a 60Hz refresh rate" . Need a good test video.
TapeStreamer
Fri Mar 27, 2020 1:26 pm
gkreidl, thanx for the info
neilgl, thanx for testing, good to know......
im sorting out which cooler to buy, i dont think a heatsink is enough
gkreidl
Fri Mar 27, 2020 1:28 pm
I use a Flirc case which acts as cooler. Nice and efficient,
neilgl
Fri Mar 27, 2020 3:09 pm
I use a flirc case. No noise.
Now going to buy a Zgemma H9.2S...
Return to “Beginners”
