Nevals_zgb
Problem after changing to CLI boot
Tue Mar 24, 2020 5:57 pm
when I change boot fo CLI in raspi-config I have this error:
pi@raspberrypi:~ $ sudo raspi-config
Removed /etc/systemd/system/default.target.
Created symlink /etc/systemd/system/default.target → /lib/systemd/system/graphical.target.
rm: cannot remove '/etc/systemd/system/getty@tty1.service.d/autologin.conf': No such file or directory
And after I reboot Pi and start GUI with sudo startx there is no trash and other icons on desktop etc.
Can you help me please with this problem?
Thank you
Re: Problem after changing to CLI boot
Tue Mar 24, 2020 6:21 pm
Don't use sudo. You'll break the GUI.
Run
sudo chown -R pi:pi /home/pi
Then start Xwindows with startx [NO SUDO]
Nevals_zgb
Tue Mar 24, 2020 6:50 pm
Ok, thank you. I will run startx without sudo
What about this error after changing boot to CLI? Is this ok?
DirkS
Tue Mar 24, 2020 6:55 pm
That should be fine. raspi-config tries to change a setting that does not need changing (just to make sure that the setting is correct)
If you get this kind of messages during boot it could indicate a problem...
