tennisparty
Systemd - script running on boot and shutdown
Mon Mar 23, 2020 8:59 pm
I have created a systemd service which runs a python script just after boot. I am having a problem that the python script is running a second time when the pi starts shutting down. Pi Model3A+ running the most recent version of Buster. I am using the python code to calculate dusk and dawn times so that the project is only on when it is dark (between sunset and sunrise - I am using a mopi to trigger shutdown/ boot times).
My systemd file looks like this -
[Unit]
Description=astralatstart
After=time-sync.target
[Service]
ExecStart=/usr/bin/python3 -u astralcalc.py
WorkingDirectory=/home/pi/Desktop
StandardOutput=append:/home/pi/Desktop/xastralcalc.log
StandardError=inherit
Restart=no
[Install]
WantedBy=multi-user.target
My project is dependent on an RTC (DS 3231) to keep time - the project will be setup in a forest well away from Wifi or a data connection so this will count time. I setup the RTC based on this guide - modifying slightly to allow for the fact I am running Buster https://spellfoundry.com/sleepy-pi/sett ... an-jessie/
Is there a reason that the script is re-running on shutdown and is there a way for me to add an additional dependency in the systemd service file so that my python script only runs at startup?
Many thanks,
Sam
Jim Danner
Re: Systemd - script running on boot and shutdown
Wed Mar 25, 2020 12:46 pm
How have you set up the running at boot? Normally you'd have an [Install] section with an entry
WantedBy=...
and then the command
sudo systemctl enable astralatstart
would create a symlink to your unit file in the right place. Have you created that symlink yourself? Where?
DarkElvenAngel
Wed Mar 25, 2020 1:13 pm
[Unit]
[Service]
Restart=no
[Install]
Many thanks,
Sam
I'm throwing a theory here but it might be after time-sync.target that's doing it.
Since your pi will synchronization time again at shutdown. This could be wrong
tennisparty
Wed Mar 25, 2020 9:35 pm
WantedBy=...
Hi Jim I have run
following this https://www.raspberrypi.org/documentati ... systemd.md
The systemd service file is saved in /etc/systemd/system
Would it be possible to explain how I would add an install section in a little more detail, or an appropriate target in the wantedby line, I don't quite catch your drift,
Sorry I'm quite new to systemd
Thanks for your help,
Sam
tennisparty
Wed Mar 25, 2020 9:36 pm
[Unit]
[Service]
Restart=no
[Install]
Many thanks,
Sam
[/quote
My thoughts exactly I was hoping I could add a second dependency which means the code runs after the time sync but only on boot
DarkElvenAngel
Wed Mar 25, 2020 10:12 pm
[Unit]
[Service]
Restart=no
[Install]
Many thanks,
Sam
Try
After=basic.target
bls
Contact: Twitter
Thu Mar 26, 2020 12:17 am
Maybe systemd thinks that running ExecStart is the right thing to do on shutdown, but I didn't see anything in the systemd.service documentation indicating that a service's ExecStart would get called again on system shutdown.
Have you tried adding something like ExecStop=/bin/true ?
tennisparty
Thu Mar 26, 2020 8:57 am
Hi, just so I understand what will that do, the docs say the following
ExecStart
The commands and arguments executed when the service starts.
ExecStartPre, ExecStartPost
Additional commands that are executed before or after the command in ExecStart.
ExecReload
The commands and arguments to execute when the service reloads.
ExecStop
The commands and arguments to execute when the service stops.
ExecStopPost
Additional commands to execute after the service stops.
I don't think I need a command executed after my original python file, or is it creating a file to say that it has already run like
RemainAfterExit
A boolean value that specifies whether the service shall be considered active even if all its processes exited. Defaults to no
Thanks again,
Sam
Jim Danner
Fri Mar 27, 2020 1:46 pm
Hi Jim I have run
The command systemctl enable can only work on a unit file that has an [Install] section. I just tried running the command on your unit file from your first post, and the answer I get is
The unit files have no installation config (WantedBy=, RequiredBy=, Also=,
Alias= settings in the [Install] section, and DefaultInstance= for template
units). This means they are not meant to be enabled using systemctl.
So I don't understand how you got your service to run automatically at all.
Are you sure you haven't created some symlink to the unit file somewhere?
DarkElvenAngel
Fri Mar 27, 2020 3:30 pm
Hi Jim I have run
There is an install section scroll the code window
[Install]
It's there so you are chasing a bad copy paste
tennisparty
Sat Mar 28, 2020 11:49 am
Hello, thanks for your help, some useful thoughts. Unfortunately I tried them but none worked. I have realised its probably an error on my part when describing the problem. I still need some advice. I had assumed the pi was rerunning the script on shutdown but I think it is actually running the script on startup, once before the rtc (or network) syncs the time, then it is rerunning the script when the time is synced (by the rtc or network).
The first time my code runs it thinks the time is still the same as when the pi shutdowns. The second time it runs the time is correctly updated.
Does anyone have an idea why the original after=time-sync dependency would cause this behaviour. I am going to try changing the systemd script to
After=basic.target
[Service]
Type=idle
Here's hoping,
Sam
Jim Danner
Tue Mar 31, 2020 12:33 pm
It seems that systemd is acting in unexpected ways again (what a surprise!).
As discussed here, the time-sync.target
does not help much because this is only for initializing the time-sync service. After intitializing it needs some time to connect to the time server and get the clock synchronized to it.
In other words, your service will run after the time-synchronization service has started, but by then it hasn't actually got the right time yet.
The same discussion provides the solution, at least for systemd past version 239 (check this with systemctl --version ): you specify After=time-sync.target as you did, but you must also have the service systemd-time-wait-sync enabled on your system. This is done with
sudo systemctl enable systemd-time-wait-sync
If that post is correct, it should then work.
Tue Mar 31, 2020 2:22 pm
Have you been running BRANCH=next rpi-update? There's a critical Linux system timer bug in that.
Jim Danner
Tue Mar 31, 2020 3:45 pm
Are you asking the OP? I'm just quoting from a thread on StackExchange, which says this is a general systemd quirk, not a problem of any particular version.
Return to “Raspbian”
