Mon Mar 23, 2020 9:24 am
Hi.
No you can't just connect 5V to your alarm panel from the pi,
The alarm panel is designed to work at nominal 12V, so the pir sensors would not work at 5V,
the door switches will have termination resistors again designed for 12V operation.
To use the pir sensors you would need to provide 12V DC to the terminals +/- and then use the N/C terminals like any other switch connected to your pi.
To use the door switch wiring is complicated due to the long wiring runs, you would probably need to remove the termination resistors and then again use the switches like any other switch connected to the pi, but due to the long cable runs they may not work correctly at 3.3v.
So you would need to run them at a higher voltage and have an interface circuit at the pi gpio as the gpio can't have any voltage higher than 3.3V connected to it.
You may be better using 12V for all the existing alarm wiring/pir's and then have opto isolators between the pi gpio and the wiring to interface at the correct voltages.
