When I run a Python script natively on the RPi, it can run indefinitely. When I have Greengass run a Python Lambda on the same device (very similar script, since I copy/pasted most of the code), it tends to fail after an hour or two with the following error in the GG logs:
[2020-03-12T10:28:59.787-05:00][ERROR]-ipc_client.py:67,<urlopen error [Errno 16] Device or resource busy>
[2020-03-12T10:28:59.787-05:00][ERROR]-Traceback (most recent call last):
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/usr/lib/python3.7/urllib/request.py", line 1317, in do_open
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/usr/lib/python3.7/http/client.py", line 1244, in request
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/usr/lib/python3.7/http/client.py", line 1290, in _send_request
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/usr/lib/python3.7/http/client.py", line 1239, in endheaders
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/usr/lib/python3.7/http/client.py", line 1026, in _send_output
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/usr/lib/python3.7/http/client.py", line 966, in send
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/usr/lib/python3.7/http/client.py", line 938, in connect
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/usr/lib/python3.7/socket.py", line 707, in create_connection
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/usr/lib/python3.7/socket.py", line 748, in getaddrinfo
[2020-03-12T10:28:59.787-05:00][ERROR]-OSError: [Errno 16] Device or resource busy
[2020-03-12T10:28:59.787-05:00][ERROR]-During handling of the above exception, another exception occurred:
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/runtime/python/greengrass_ipc_python_sdk/ipc_client.py", line 59, in wrapped
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/runtime/python/greengrass_ipc_python_sdk/ipc_client.py", line 174, in post_work
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/usr/lib/python3.7/urllib/request.py", line 222, in urlopen
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/usr/lib/python3.7/urllib/request.py", line 525, in open
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/usr/lib/python3.7/urllib/request.py", line 543, in _open
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/usr/lib/python3.7/urllib/request.py", line 503, in _call_chain
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/usr/lib/python3.7/urllib/request.py", line 1345, in http_open
[2020-03-12T10:28:59.787-05:00][ERROR]- File "/usr/lib/python3.7/urllib/request.py", line 1319, in do_open
Here is the actual Lambda function I am publishing to the RPi-GG core:
import logging
import platform
from threading import Timer
import sys, time
import greengrasssdk
from spidev import SpiDev
class MCP3008:
def __init__(self, bus = 0, device = 0):
self.bus, self.device = bus, device
self.spi = SpiDev()
self.open()
self.spi.max_speed_hz = 1000000 # 1MHz
def open(self):
self.spi.open(self.bus, self.device)
def read(self, channel = 0):
cmd1 = 4 | 2 | (( channel & 4) >> 2)
cmd2 = (channel & 3) << 6
adc = self.spi.xfer2([cmd1, cmd2, 0])
data = ((adc[1] & 15) << 8) + adc[2]
return data
def close(self):
self.spi.close()
# Setup logging to stdout
logger = logging.getLogger(__name__)
logging.basicConfig(stream=sys.stdout, level=logging.DEBUG)
# Creating a greengrass core sdk client
client = greengrasssdk.client("iot-data")
# Retrieving platform information to send from Greengrass Core
my_platform = platform.platform()
def read_MCP3008():
try:
mcp = MCP3008()
raw_ch1 = mcp.read(0)
raw_ch2 = mcp.read(1)
raw_ch3 = mcp.read(2)
raw_ch4 = mcp.read(3)
raw_ch5 = mcp.read(4)
raw_ch6 = mcp.read(5)
raw_ch7 = mcp.read(6)
raw_ch8 = mcp.read(7)
client.publish(
topic="iot_sensors/mcp3008/ch1",
queueFullPolicy="AllOrException",
payload=str(raw_ch1)
client.publish(
topic="iot_sensors/mcp3008/ch2",
payload=str(raw_ch2)
client.publish(
topic="iot_sensors/mcp3008/ch3",
payload=str(raw_ch3)
client.publish(
topic="iot_sensors/mcp3008/ch4",
payload=str(raw_ch4)
client.publish(
topic="iot_sensors/mcp3008/ch5",
payload=str(raw_ch5)
client.publish(
topic="iot_sensors/mcp3008/ch6",
payload=str(raw_ch6)
client.publish(
topic="iot_sensors/mcp3008/ch7",
payload=str(raw_ch7)
client.publish(
topic="iot_sensors/mcp3008/ch8",
payload=str(raw_ch8)
except Exception as e:
logger.error("Failed to publish message: " + repr(e))
client.publish(
topic="iot_sensors/mcp3008",
payload="Try statement failed: " + repr(e)
# Asynchronously schedule this function to be run again in 5 seconds
Timer(1, read_MCP3008).start()
read_MCP3008()
def lambda_handler(event, context):
return
Thanks!
