black_tiger
Boot from microsd on laptop
Thu Mar 19, 2020 5:43 pm
Im trying to boot the raspbian OS from the microsd card (inserted to my laptop).
My raspberry overclocked, and i need some files for my current web development project.
I've tried the Oracle VirtualBox software in as a virtual enviorment and failed.
Please help me fix this problem, for it will save me some valuable time (re-making those web pages files, which exist on the OS microsd)
this is my first post, hope this is the right forum.
FTrevorGowen
Re: Boot from microsd on laptop
Thu Mar 19, 2020 6:45 pm
You shouldn't need to (literally) boot Raspbian in a virtual Linux environment. All you need is either Linux filesystem-compatible tools for your laptop's O.S. (what is it? - I'm guessing a version of Windows) or something like a Live Linux system on a USB stick/DVD if your laptop has enough USB ports and/or a SD card slot. It may even be possible to arrange for the PC specific version of Raspbian: viewforum.php?f=116 to be run as a "Live Linux System". Certainly such exist for Debian, Ubuntu and others.
Whilst I can't give you detailed help, hopefully there are enough hints there that a bit of web searching will get you going again.
W.r.t. your Pi - all you state is that "My raspberry overclocked" - some more detail about what has happened, why you can't use it anymore etc. may help us to advise you whether it can be got working again. For example, if it's not booting from the current card, have you tried a different SD card with a fresh install w/o any overclocking etc. active? If that works you could then recover those web pages from the original card via a USB card reader.
HTH
Trev.
Thu Mar 19, 2020 6:47 pm
Raspbian Buster Operating System is only suitable for Raspberry Pi Single Board Computers and Compute Module.
It is not possible to boot any other PC / Laptop.
It is not possible to use in VirtualBox because it can not emulate the ARM CPU Architecture.
RPi 4B 4GB (SSD Boot)..
B.Goode
Thu Mar 19, 2020 6:48 pm
Welcome to the Raspberry Pi forums.
"Im trying to boot the raspbian OS from the microsd card (inserted to my laptop)."
Is this laptop a fairly normal everyday PC or Mac?
If so, you can't boot that hardware using the Raspbian Operating System. Raspbian will only boot and run on Raspberry Pi arm-based hardware.
Edit: playing Snap again. The forum software used to warn when that was happening...
alphanumeric
Thu Mar 19, 2020 7:51 pm
The first question is, can said laptop even boot from the SD Card slot? I ask because mine cannot boot from its card reader writer SD card slot. There is no BIOS option to do this, period. If yours is also like this it makes no difference what is on the card, its not accessible on boot up.
Botspot
Fri Mar 20, 2020 1:47 am
Very strange nobody has looked past the surface and seen the real question: How to recover data from the filesystem of a Raspbian SD card?
Answer: Your laptop (Windows) cannot access the type of filesystem Raspberry Pi uses. Windows can access NTFS partitions and FAT32 partitions. That's why your laptop likely showed you only the boot partition, but not the root partition.
The root partition is EXT4, a type of partition that Windows is clueless on how to show you.
If you have a linux laptop handy, use that to access the filesystem. (Raspbian is Linux)
But if not, probably the easiest way is to buy a second SD card which I'll call card 2. Boot the Pi on card 2, plug in card 1 using a usb card reader, and copy off the files.
To keep this from happening again, back up your Pi regularly. Easy - just use SD Card Copier from the menu to copy everything from card 1 to card 2.
If card 1 fails, gets lost, gets cracked, or doesn't boot, just switch to card 2 (the backup) and keep going.
Sidenote: If accessing card 1's filesystem is not enough, but you need to boot it like you asked - easy. I've made a handy Raspbian utility called Pi-Power-Tools to edit Sd cards and Raspbian images.
In your case, you would be interested in the boot option: select the usb card reader containing the damaged card 1, then click boot.
You can play around with the desktop and type commands in the console, just as if you actually booted card 1.
https://github.com/Botspot/Pi-Power-Tools
I've developed the most intuitive RaspiOS img editor on the planet.
With a GUI similar to Gparted, managing imgs and sd cards is a breeze!
Boot it in a VM, Flash from the Internet at top speed, Mount (to drop in files), Shrink/Expand, Repair, and more.
> 400 users! 8-)
B.Goode
Fri Mar 20, 2020 8:44 am
Re-read the first response, from a Moderator.
bensimmo
Fri Mar 20, 2020 8:55 am
One method would be to get the RaspberryPi Desktop x86 and boot to that on a pendrive or CD if you can.
You can then read the uSD card (if it has the drivers for the SD card) and you can save to the harddrive or Google Drive etc
Or
Installing Ubuntu/RPD Desktop to a virtual machine of some sort.
Or
Install the Windows Linux Subsystem and read via that (I think you can do that now)
Or
Use diskinternal Linux reader
https://www.diskinternals.com/linux-reader/
EDIT
Or
If your router has a USB port to create a Samba share etc (mine does that came from my ISP). You can access it via that, at least with my Technicolor as it support ext3/4 )
While you are there, go into the FAT folder windows can see, edit config.txt and remove the overclocking settings, especially the you one.
You may be able to use you Pi again.
Return to “Beginners”
