aminsadati1374
problem on reading sensor max30100 with Raspberry Pi3
Tue Mar 17, 2020 11:38 am
hi, I want to connect the sensor max30100 to the Raspberry Pi board. I followed this.
https://github.com/vrano714/max30102-tu ... aspberrypi
I think everything is accurate. But the sensor doesn't turn on and it doesn't happen to the program. I'm happy someone helps. I'm a beginner.
B.Goode
Re: problem on reading sensor max30100 with Raspberry Pi3
Tue Mar 17, 2020 11:59 am
Welcome to the Raspberry Pi forums.
Maybe the author/developer/maintainer of the code is the best source of advice?
https://github.com/vrano714/max30102-tu ... ypi/issues
Did you carry out the prerequisite steps listed in the documentation here: https://github.com/vrano714/max30102-tu ... errypi#run
There is some troubleshooting advice from the author here: https://github.com/vrano714/max30102-tu ... i/issues/3
If you want to pursue the problem here you will probably need to indicate what Operating System is running on your RPi 3 board, and provide an example of what happens when you try to run the code. For example, there are 3 sample scripts in addition to the library module itself. Have you tried all 3? What actually happens?
A clear, focussed photo of the wiring between the sensor and your RPi might also allow the cabling to be checked.
Return to “Python”
