zulihomevn
UDP Problem
Mon Mar 16, 2020 3:58 am
I created a socket
int rx_sock;
struct sockaddr_in server, from;
int UDP_Init(void)
    rx_sock = socket(AF_INET, SOCK_DGRAM, 0);
    if (rx_sock < 0)
        printf("socket create error\n");
        return -1;
    else
        printf("socket created %d\n", rx_sock);
    #if 1
    server.sin_family = AF_INET;
    server.sin_addr.s_addr = INADDR_ANY;
    server.sin_port = htons(8101);
    if (bind(rx_sock, (struct sockaddr *) &server, sizeof(server)) != 0)
        printf("socket bind error\n");
        return -1;
    else
        printf("socket bind success\n", rx_sock);
    #endif
    return 0;
int UDP_Read(uint8_t *rx_buf, int rx_size)
    int len;
    socklen_t socklen;
    len = recvfrom(rx_sock, rx_buf, rx_size, 0, (struct sockaddr *)&from, &socklen);
    return len;
Re: UDP Problem
Mon Mar 16, 2020 4:49 pm
I created a socket
That sounds like the start of a great story.
Can't wait to hear what happened next...
StuartF
Re: UDP Problem
Mon Mar 16, 2020 10:19 pm
I'm wondering where the CODE: was SELECT from.... :shock:
LdB
Re: UDP Problem
Tue Mar 17, 2020 2:28 am
Change the 0 in recvfrom to MSG_WAITALL .. it isn't zero on all versions of linux
That assumes you are actually calling the UDP_Read because you don't show us that and I am assuming you have a "main"
Return to “C/C++”
