The Red LED is on. The green LED does the normal intermittent flickering pattern as it starts booting. There is one long green flash, then the rainbow screen appears on HDMI, and the green LED never blinks again. The rainbow screen never changes.
powering up without SD-card produces the expected 4 flashes. Examining the SD-card in another computer shows the boot files are intact and look normal.
I've read the sticky post on boot issues, and didn't find this case covered. Is there any additional guidance?
Edit: I tried the bootloader fix:
Download the bootloader
SHA-256: 444e0f68aa21d5b4e158259061de55738d36a1986e2ced14bb14d7af1a04881c
Extract it to an empty FAT-formatted SD card and insert it into your Raspberry Pi 4
Connect the power and wait for the green LED to flash quicklyIt succeeded, and I saw the fast green LED flash. However, the Pi still has the same boot failure as above.
Note - the instructions above say "FAT" formatted, but that is not an option. Only FAT32 and NTFS are available in Windows 10.
I'm assuming that FAT32 is also supported since the processed ended with a fast green LED flash, but I could be wrong.
