DeeZii
Problem with USB Hub on a Pi Zero
Sat Mar 14, 2020 11:54 am
Hello everyone
I recently bought a USB hub for my Pi Zero and the Pi Zero restart each time when I plug a keyboard or a mouse. And it didn’t recognize it and today I’m asking you if someone had this problem with this hub and most important have the solution to get it working.
I bought it on Amazon. There is the link to the product.
https://www.amazon.fr/gp/product/B07TBK ... UTF8&psc=1
So, let me know if someone had this problem or if I need an other HUB that is compatible with the Pi !
PS : Sorry for my English ! 😉
PhatFil
Re: Problem with USB Hub on a Pi Zero
Sat Mar 14, 2020 1:14 pm
its a known issue.. viewtopic.php?t=189921
as for the hub to use to avoid the problem? No Offence intended.. You will probably have the best results using a branded hub that conforms to standards rather than a cheaper unbranded option
DeeZii
Sat Mar 14, 2020 3:57 pm
Thanks for the answer I will try if it dose not work I will buy a branded one
ejolson
Sat Mar 14, 2020 4:26 pm
Is the recommended solution a powered hub or a better supply for the Zero?
alphanumeric
Sat Mar 14, 2020 4:37 pm
I'm currently using this very similar hub with My Pi Zero's with no issues. No reboots when pluging and unpluging USB devices from the Hub. Plugging the Hub in after the Pi boots up will likely make it reboot though. I just make sure its plugged in before powering up.
https://shop.pimoroni.com/products/thre ... -connector
DeeZii
Sun Mar 15, 2020 10:04 am
Well I will order this one then to try, if it will not work I will have to keep using my wireless keyboard and mouse in one ! x)
Imperf3kt
Sun Mar 15, 2020 9:44 pm
The recommended solution is to not hot plug usb devices on a Pi Zero (or A model)
Plug in everything you need, before you boot.
55:55:44:44:4C
52:4C:52:42:41
