shane256
Raspberry Pi Imager and Raspberry Pi 3B
Fri Mar 13, 2020 1:37 am
I have a Raspberry Pi 3B. The 4 is out as well as the other models. When I'm in the Raspberry Pi Imager, I can make a Raspbian image but it doesn't say specifically which models that image supports. Do Raspbian images support all the models of Raspberry Pi? For example, if I made an image, could I take use it on the 3B and a 4 as well?
Re: Raspberry Pi Imager and Raspberry Pi 3B
Fri Mar 13, 2020 7:00 am
Yes. Currently, at least. There is a possibility that a separate image may appear at some stage that will only work on the later models of Pi that have 64-bit capable CPUs. But there will still be an image that works on the Pi 0-4 in 32-bit mode for quite a few years to come.
Unreadable squiggle
FTrevorGowen
Fri Mar 13, 2020 10:22 am
+1 but adding the reminder that older images will probably not work on newer Pi's since such (future) Pi's are likely to need firmware that the old image doesn't have.
Trev.
alphanumeric
Fri Mar 13, 2020 10:26 am
There is a table here that will tell you what runs on what Pi.
https://en.wikipedia.org/wiki/Raspbian
B.Goode
Fri Mar 13, 2020 10:37 am
A useful form of presentation. But it is a Wikipedia page with no assurance of accuracy.
I would prefer to trust the Raspbian Release Notes published by Raspberry Pi themselves - http://downloads.raspberrypi.org/raspbi ... _notes.txt
I can see at least one place where the information differs. (I don't feel motivated enough to learn to be a Wikipedia editor.)
shane256
Fri Mar 13, 2020 12:24 pm
Thanks all... exactly what I needed to know.
