Hi, Were doing a project called "Automatic Moss Removing Machine" which uses OpenCV Haar Cascade for detecting moss and raspberry Pi as our main controller.
Im having a problem regarding the Camera because, whenever I detect distance using Ultrasonic Sensor, my camera freeze. What I want to do is:
> If Camera detects moss, Clean using Power Washer
>If Ultrasonic sensor detects a certain distance, the Power Washer won't turn on.
Heres my script:
import numpy as np
import cv2
import threading
import time
import RPi.GPIO as GPIO
import time, sys, os
import multiprocessing
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
#OpenCV Prereq
mossCascade= cv2.CascadeClassifier('e.xml') #E = Low Accuracy
cap = cv2.VideoCapture(0)
ret = cap.set(cv2.CAP_PROP_FRAME_WIDTH,250)
ret = cap.set(cv2.CAP_PROP_FRAME_HEIGHT,250)
#Right Wheel
GPIO.setup(6, GPIO.OUT)
GPIO.setup(13, GPIO.OUT)
#Left Wheel
GPIO.setup(20, GPIO.OUT)
GPIO.setup(21, GPIO.OUT)
#Center
GPIO.setup(17, GPIO.OUT)
GPIO.setup(27, GPIO.OUT)
#Power Washer
GPIO.setup(18, GPIO.OUT)
#Utrasonic
TRIG = 23
ECHO = 24
GPIO.setup(TRIG, GPIO.OUT)
GPIO.setup(ECHO, GPIO.IN)
mossDetector = False
mossFlag = 0
def MossDetection():
global mossDetector
global counter
global mossFlag
counter = 0
while True:
ret, img = cap.read()#Get camera data
gray = cv2.cvtColor(img, cv2.COLOR_BGR2GRAY) #declare the parameters for multisclae
moss = mossCascade.detectMultiScale(gray, 1.2, 3) #1.1 scale medium
for (x,y,w,h) in moss: #draw square sa fez
cv2.rectangle(img,(x,y),(x+w,y+h),(255,0,0),2)
roi_gray = gray[y:y+h, x:x+w]
roi_color = img[y:y+h, x:x+w]
mossDetector = True
print("moss Detected")
if(mossDetector == True):
getDistance = GetDistance()
if(getDistance >=25):
print("Cleaning")
Forward()
counter = 0
else:
print("Obstacle Detected")
counter = 0
else:
Stop()
counter += 1
if (counter >= 100):
print("Vehicle Turning")
counter = 0
if(mossFlag == 0):
print("Turning Left")
TurnToLeft()
mossFlag = 1
print("Flag = 1")
elif(mossFlag == 1):
TurnToRight()
print("turning Right")
mossFlag = 0
print("Flag = 0")
#print(counter)
cv2.imshow('img',img)
if cv2.waitKey(1) == ord('q'):
break
#Vechicle Forward
def Forward():
GPIO.output(6, 0)
GPIO.output(13, 1)
GPIO.output(20, 0)
GPIO.output(21, 1)
GPIO.output(18, 0)
def Backward():
GPIO.output(6, 1)
GPIO.output(13, 0)
GPIO.output(20, 1)
GPIO.output(21, 0)
def RightTurn():
GPIO.output(6, 0)
GPIO.output(13, 1)
GPIO.output(20, 1)
GPIO.output(21, 0)
def LeftTurn():
GPIO.output(6, 1)
GPIO.output(13, 0)
GPIO.output(20, 0)
GPIO.output(21, 1)
def Stop():
GPIO.output(18, 1)
GPIO.output(6, 0)
GPIO.output(13, 0)
GPIO.output(20, 0)
GPIO.output(21, 0)
GPIO.output(17, 0)
GPIO.output(27, 0)
def TurnToLeft():
LeftTurn()
time.sleep(7)
Forward()
time.sleep(8)
LeftTurn()
time.sleep(2.5)
Backward()
time.sleep(5)
def TurnToRight():
RightTurn()
time.sleep(7)
Forward()
time.sleep(8)
RightTurn()
time.sleep(2.5)
Backward()
time.sleep(5)
def GetDistance():
GPIO.output(TRIG, True)
time.sleep(0.00001)
GPIO.output(TRIG, False)
while GPIO.input(ECHO) == 0:
pulse_start = time.time()
while GPIO.input(ECHO) == 1:
pulse_end = time.time()
pulse_duration = pulse_end - pulse_start
distance = pulse_duration * 17150
distance = round(distance, 2)
print("Distance: " + str(distance) +" cm")
return distance
MossDetection()
Stop()
GPIO.cleanup()
cap.release()
cv2.destroyAllWindows()
