Model: Pi 4 Model B Rev 1.2
OS: Linux raspberrypi 4.19.97
I've had my Pi up and running for a couple weeks (on a monitor, not TV). It started, and has been displaying, in 1920x1080 resolution. I've rebooted several times and it always came up 1920x1080. Today, however, it booted to 1024x768 and I can no longer get it to display in 1920x1080.
Using the Screen Configuration tool it shows 1920x1080 as an option. When I select it my screen blanks, then displays "Input Not Supported" for a few seconds, then reverts to 1024x768.
I also tried setting it with raspi-config from CLI. It had no effect.
I booted in recovery mode and confirmed config.txt has the values
hdmi_group=2
hdmi_mode=82
When exiting recovery mode and continuing to boot I get the same "Input Not Supported" and then the 1024x768 screen.
I've tested the monitor on a different computer and it can display 1920x1080. I tried the Pi on a different monitor and it has the same effect. So I've ruled out a monitor problem.
Any advice is appreciated.
SC
