- RaspbianUser1
Re: Pi Power Tools: General Purpose Disk Image & SD Card Manager
Yes of course
Running either Raspberry Pi OS desktop Full or Raspberry Pi OS MATE desktop
Overclocked at 2147MHz CPU and 700 MHz GPU with a over voltage of 7, max or nothing
Think before you delete something a stranger on the internet told you to.
OK, and what about my other 2 questions?:
Once again: are you using my vdesktop beta version?
And what command do you have to run for this mate desktop to launch?
Also, does running x-terminal-emulator launch a terminal on your system? Or do you get "command not found"?
Want to run Minecraft Java on your RPi? Easiest way is with Pi-Apps - just click Install.
https://github.com/Botspot/pi-apps
Pi-Apps also includes Zoom, Visual Studio, Tor browser, Windows 10 theme, and 33 more.
Over 50,000 users!
Over 50,000 users!
- RaspbianUser1
Sorry my mistake
I will answer all
Using beta, No
Desktop, mate-session however I retested and it doesn’t work on vdesktop, however when choosing a different tty than 7 on the the actual machine, running sudo lightdm | mate-session gives a terrible resolutioned DE
x-terminal emulator it does have it installed but im on CLI only on vdesktop
I will answer all
Using beta, No
This is interesting. Do you know if there is an img with a mate desktop, that I could download, for testing on vdesktop?RaspbianUser1 wrote: ↑Mon Oct 19, 2020 11:16 pmDesktop, mate-session however I retested and it doesn’t work on vdesktop, however when choosing a different tty than 7 on the the actual machine, running sudo lightdm | mate-session gives a terrible resolutioned DE
If there aren't any images available, would you consider uploading your image so I can ensure it works?
Over 50,000 users!
Over 50,000 users!
- RaspbianUser1
Sorry there are no MATE raspbian images publicly available and I would not give you mine due to sensitive data I would have to find and remove
However its easy to get a basic install following a guide
https://www.raspberrypi.org/forums/vie ... p?t=133691
It takes about 20 minutes on a fast connection speed
Make sure you start it on Lite
Awesome tool !!
Especially boot function is very useful.
I ran PiPowerTools on Pi4B/4GB, kernel 5.10.
Booting works out of the box. Plenty of free memory - about 0,5GB used.
I switched to 64bit kernel and boot 64bit images too.
Making remixes of rpios is very simple.
In youtube 5 -10fps - can be watched.
One small problem - dphys-swapfile do not work in vdesktop.
Good job !!
Good job !!
Pi4 Raspos LXQT remix/32bit
The option to create incremental images is really interesting but when attempting to create an image of my SD card using the following procedure:
IMG MODE -> SD to IMG, specify name and location, click OK
I get the error:
sudo: no tty present and no askpass program specified
Michael
I get the error:
Michael
Hmm. I've never seen that error before.michael9000 wrote: ↑Sun Dec 13, 2020 1:58 amThe option to create incremental images is really interesting but when attempting to create an image of my SD card using the following procedure:
I get the error:
What OS are you running, and did you happen to disable passwordless-sudo ability for the non-root user?
Over 50,000 users!
Over 50,000 users!
Thanks for your reply.
I had turned off passwordless-sudo ability. I turned it back on and its working fine.
Thankyou. Excellent software support.
So, a feature request, could the option for the user to enter the password at the time PPt creates the image be implemented? Rather than disabling need system wide.
Michael
Michael
I have considered doing exactly that, but considering the time required, and the tiny number of users who would actually benefit, I concluded it wasn't worth the time/effort.michael9000 wrote: ↑Sun Dec 13, 2020 2:38 amSo, a feature request, could the option for the user to enter the password at the time PPt creates the image be implemented? Rather than disabling need system wide.
Now, if someone would like to submit a PR...
Over 50,000 users!
Over 50,000 users!
I send a patch with similar functionality:
https://github.com/Botspot/Pi-Power-Too ... 1?expand=1
Regards.
hi Botspot,
After several weeks, i tried to install pi power tools on my rpi 4 4 gb, 128 gb card
installation went fine, i downloaded 3.7 gb img,
but on clicking booth it is getting stuck in boot console showing
Systemd-nspawn, Xephyr and Expect need to be installed for vdesktop to work. Proceed? [Y/n]
and nothing happens, i made image of buster 5 times, but boot failed 3 times showing some dependency failed,
2 times i got this issue
mounted /media/pi/vdesktop/etc/chromium-browser/customizations/noxshm
Mounted /media/pi/vdesktop/etc/chromium-browser/customizations/disable-gpu
Virgilrenderer server not found, but it's enabled in the config file.
Compiling virglrenderer in 10 seconds. To cancel, press Ctrl+C before then.
Failed to clone virglrenderer repository!
and no boot happens
please check for issue.
and no boot happens
Uhh, did you try pressing the Y key and hitting Enter?neal1 wrote: ↑Sat Jan 09, 2021 8:01 pmhi Botspot,
and nothing happens, i made image of buster 2 or 3 times, but boot always fails showing some dependency failed, please check for issue.
And do you happen to be on a 64bit OS?
Over 50,000 users!
Over 50,000 users!
There was no option to press Y option it was opening in Boot console. unbale to click anything inside, though could copy.
it only stuck there
i am using 32 bit OS
it only stuck there
On the keyboard, type y. Then press Enter. On the keyboard.
Over 50,000 users!
Over 50,000 users!
i tried no success
https://ibb.co/h2gKgsM
No intent to push your thread to other side, but no way to contact you either way,
i am assuming that pi tools helped in adding dependencies automatically for my requirements for multi seat setup.
as i am facing issue in setup it, it worked for me few months earlier now i am unable to replicate result using same instructions viewtopic.php?t=243572
only difference left in equation is dependencies like xypher, yad, light dm.
Update
dependencies are installed successfully, but now error coming is Virgilrenderer server not found
failed to install dependencies for virgilrenderer
Hmm, then maybe it's time to stop using Pi Power Tools to run vdesktop virtual machines, and just use vdesktop standalone.
git clone https://github.com/Botspot/vdesktop
sudo ENABLE_VIRGL=no ~/vdesktop/vdesktop /path/to/your.img
Over 50,000 users!
Over 50,000 users!
still not working
pi@raspberrypi:~ $ git clone https://github.com/Botspot/vdesktop
Cloning into 'vdesktop'...
remote: Enumerating objects: 186, done.
remote: Counting objects: 100% (186/186), done.
remote: Compressing objects: 100% (141/141), done.
remote: Total 384 (delta 94), reused 81 (delta 30), pack-reused 198
Receiving objects: 100% (384/384), 2.73 MiB | 2.16 MiB/s, done.
Resolving deltas: 100% (197/197), done.
pi@raspberrypi:~ $ sudo ENABLE_VIRGL=no ~/vdesktop/vdesktop /path/to/your.img
Current config:
VDESKTOP_BOOT_MODE: gui
VDESKTOP_UMOUNT_ON_EXIT: yes
VDESKTOP_USERNAME: pi
VDESKTOP_PASSWORD: raspberry
VDESKTOP_AUTO_LOGIN: yes
VDESKTOP_MOUNTPOINT: /media/pi/vdesktop
VDESKTOP_ENABLE_ROOTMOUNT: yes
VDESKTOP_ENABLE_VIRGL: no
VDESKTOP_LOCAL_BINARIES: yes
VDESKTOP_NSPAWN_FLAGS:
Message from Botspot: Comments >/dev/null. Just kidding! Questions or suggestions? viewtopic.php?&t=251757
No such file or directory. Check spelling and try again.
Available devices:
PATH MODEL SIZE
/dev/mmcblk0 119.1G
find: ‘/root/Downloads’: No such file or directory
Boot a .img file: vdesktop /home/pi/2020-08-20-raspios-buster-armhf.img
Boot a usb drive: vdesktop /dev/sda
Boot a directory: vdesktop /home/pi/raspbian-stretch/
A second word specifies the boot mode: cli, cli-login, and gui.
Hold on...
Cleaning up...
umount: /media/pi/vdesktop/boot: no mount point specified.
umount: /media/pi/vdesktop: not mounted.
Almost done...
Done!
pi@raspberrypi:~ $ sudo ~/vdesktop/vdesktop
You did not specify what to boot.
Available devices:
PATH MODEL SIZE
/dev/mmcblk0 119.1G
pi@raspberrypi:~ $ sudo ~/vdesktop/vdesktop /home/pi/2020-08-20-raspios-buster-armhf.img
Current config:
VDESKTOP_ENABLE_VIRGL: yes
Available devices:
PATH MODEL SIZE
/dev/mmcblk0 119.1G
Hold on...
Cleaning up...
Almost done...
Done!
pi@raspberrypi:~ $ sudo ~/vdesktop/vdesktop /home/pi/raspbian-stretch/
Current config:
Available devices:
PATH MODEL SIZE
/dev/mmcblk0 119.1G
Hold on...
Cleaning up...
Almost done...
Done!
Current config:
Available devices:
PATH MODEL SIZE
/dev/mmcblk0 119.1G
Hold on...
Cleaning up...
Almost done...
Done!
Available devices:
PATH MODEL SIZE
/dev/mmcblk0 119.1G
Current config:
Available devices:
PATH MODEL SIZE
/dev/mmcblk0 119.1G
Hold on...
Cleaning up...
Almost done...
Done!
Current config:
Available devices:
PATH MODEL SIZE
/dev/mmcblk0 119.1G
Hold on...
Cleaning up...
Almost done...
Done!
How proficient are you with the command line? Have you read the instructions for vdesktop?neal1 wrote: ↑Mon Jan 11, 2021 2:06 pmstill not working
pi@raspberrypi:~ $ sudo ENABLE_VIRGL=no ~/vdesktop/vdesktop /path/to/your.img No such file or directory. Check spelling and try again. pi@raspberrypi:~ $ sudo ~/vdesktop/vdesktop You did not specify what to boot. pi@raspberrypi:~ $ sudo ~/vdesktop/vdesktop /home/pi/2020-08-20-raspios-buster-armhf.img No such file or directory. Check spelling and try again. pi@raspberrypi:~ $ sudo ~/vdesktop/vdesktop /home/pi/raspbian-stretch/ No such file or directory. Check spelling and try again.
You must specify a valid path to an image, that exists on your system, to boot it.
Over 50,000 users!
Over 50,000 users!
thanks for identifying, i am getting to understand commands at the moment,
vdesktop /home/pi/ppt-dl-2020-12-02-raspios-buster-armhf.img
vdesktop working now, but i can see bluetooth other logo spread over taskbar
Could you attach a screenshot?
Over 50,000 users!
Over 50,000 users!
