cavedog
How to Install Openmha Since It Is Ubuntu
Fri Feb 28, 2020 3:38 pm
I would like to install Openmha for my hearing aids but it is compiled in Ubuntu and does not exist in the raspberry repository. Has anyone done this? What are the steps?
topguy
Re: How to Install Openmha Since It Is Ubuntu
Fri Feb 28, 2020 4:23 pm
This guide contains the standard procedure for building.
https://github.com/HoerTech-gGmbH/openM ... e-on-linux
To install the prerequisites it should be enough to run this in a terminal.
sudo apt install libsndfile1-dev libjack-jackd2-dev jackd2 portaudio19-dev
Then if the "./configure" command doesnt kick up any error you should have a pretty good chance of success.
cavedog
Fri Feb 28, 2020 8:52 pm
That worked. Many thanks.
topguy
Fri Feb 28, 2020 10:34 pm
Can I ask what the software is actually used for ?
cavedog
Fri Feb 28, 2020 10:41 pm
I want to try to connect to my Bluetooth hearing aids but haven't gotten that far yet. If there is anyone out there who has done this, let me know!
Return to “Beginners”
