I'm trying to stream audio from one RPi 3B+ to another using nRF24 transceivers. Each RPi is connected to an RF24 to transmit and receive, and a Respeaker Mic Array V2.0 to input and output audio. I'm using Raspian and Python 3.7. I can send and receive data with the RF24's using a basic "Hello World" script, so I know they are connected correctly. And I can stream audio from the mic straight out a speaker using on the same RPi using a basic audio stream script, so I know my mics and speakers work also. When I try to transmit the audio data from one RPi to the other, however, the audio output is just a screeching beeping mess. Can anyone help? I had this working on Teensy 3.5's programmed with the Arduino IDE, so I'm fairly certain its possible o Raspberry Pi 3B+ also.
## Receive script ##
import RPi.GPIO as GPIO
from lib_nrf24 import NRF24
import time
import spidev
import pyaudio
import queue
import numpy as np
p = pyaudio.PyAudio()
q = queue.Queue(8192)
#input stream setup
stream = p.open(
rate=48000,
format=p.get_format_from_width(2),
channels=1,
input=True,
input_device_index=2,)
#output stream setup
player=p.open(format = pyaudio.paInt16,rate=48000,channels=1, output=True, output_device_index=2, frames_per_buffer=4096)
GPIO.setmode(GPIO.BCM)
pipes = [[0xe7, 0xe7, 0xe7, 0xe7, 0xe7], [0xc2, 0xc2, 0xc2, 0xc2, 0xc2]]
radio = NRF24(GPIO, spidev.SpiDev())
radio.begin(0, 17)
radio.setPayloadSize(32)
radio.setChannel(0x60)
radio.setDataRate(NRF24.BR_2MBPS)
radio.setPALevel(NRF24.PA_MIN)
radio.setAutoAck(False)
radio.enableDynamicPayloads()
radio.enableAckPayload()
radio.openReadingPipe(0, pipes[1])
radio.printDetails()
radio.startListening()
def startAudio():
while True:
if radio.available():
print ("THERE IS RADIO")
##while not radio.available():
#time.sleep(1 / 100)
#print ("no radio.available")
receivedMessage = []
radio.read(receivedMessage, radio.getDynamicPayloadSize())
q.put(receivedMessage)
chunk = 0
if q.full():
print("q full")
q.get(chunk)
data=np.frombuffer(stream.read(chunk,exception_on_overflow = False),dtype=np.int16)
player.write(data, 4096)
#stream.write(q.get())
startAudio()
## Transmit script ##
import pyaudio
import time
import time
import spidev
stream = p.open(format = pyaudio.paInt16, channels = 1, rate = 44100, frames_per_buffer = 4096, output = False, input = True, input_device_index = 2)#, stream_callback = callback)
stream.start_stream()
radio.begin(0, 17)
radio.setPALevel(NRF24.PA_MAX)
# radio.openReadingPipe(1, pipes[1])
radio.openWritingPipe(pipes[1])
def startAudio():
while True:
data2 = stream.read(4096,exception_on_overflow=False)
i=0
print ("sending")
while i<128:
radio.write(data2[i*32])
i += 1
startAudio()
