jhihn
Rpi 4 not working at 1366x768
Thu Feb 27, 2020 9:25 pm
I have a Acer K202HQL which is 1366x786@60hz
When I select this in Screen Configuration it does not work, it reverts to 1280x720.
I've modified the config.txt, and specified hdmi_mode=81
hdmi_group=2
Someone also on the forum also had issue with this...
Re: Rpi 4 not working at 1366x768
Fri Feb 28, 2020 7:27 am
We are currently looking into this, have just ordered one of these monitors for testing.
Working in the Applications Team.
jhihn
Wed Mar 04, 2020 2:40 pm
So it looks like Acer has a couple part numbers for this. https://www.acer.com/ac/en/US/content/m ... .IX2AA.A05
Is the one I have.
Allegedly, there is a version with a 1600xYYY resolution too. When you do post a result, please include the part number from the label
Wed Mar 04, 2020 2:44 pm
Is the one I have.
We've had trouble sourcing any devices with that resolution - all out of stock at places in the UK, so are currently getting one imported from one of our distributors outside of Europe. Might be a while.
jhihn
Wed Mar 04, 2020 7:06 pm
Dang, I have Amazon Prime next day here :-(
Wed Mar 04, 2020 9:22 pm
So do we, but it doesn't have any 1366x768 devices (that we have been able to find). It's an old and mostly discontinued size, usually used in laptops. I suspect its might be more common in other countries where 720p might be more common.
kerry_s
Wed Mar 04, 2020 9:51 pm
here's my config.txt settings to make it work at 1360x768@60hz for now, it's close enough it looks right.
framebuffer_width=1360
framebuffer_height=768
hdmi_group=2
hdmi_mode=39
you might have to boot into hdmi safe mode first, cause it needs to be selected in the gui to.
kerry_s
Thu Mar 05, 2020 11:29 pm
just letting you know, this also works in the config.txt.
hdmi_group=2
hdmi_cvt=1366 768 60
hdmi_mode=87
jhihn
Fri Mar 13, 2020 2:49 pm
Thank you! This has improved the display quality, but I still have large black borders around the image. I don't know if it's just that way, but the product images from Acer don't show it (though they may be photoshopped)
https://www.acer.com/ac/en/MY/content/m ... .IX2SM.A02
kerry_s
Fri Mar 13, 2020 4:53 pm
disable overscan in the preferences.
ezy_rider
Fri Mar 13, 2020 5:36 pm
My monitor has the same resolution (1366x768 60 hz NTSC). I adjusted the config.txt file as follows
disable_overscan=1
overscan_left=30
overscan_right=30
overscan_top=20
overscan_bottom=20
hdmi_mode=16
hdmi_drive=2
Works well for me..
jhihn
Mon Apr 13, 2020 4:01 pm
Had best results with
hdmi_group=2
hdmi_mode=87
hdmi_cvt=1366 768 60 3 0 0 1
BoouM
Thu Apr 16, 2020 7:29 pm
Any progress on this issue ?
I also have a television working on 1366x768@60Hz and there is no picture when hdmi_mode=81 and hdmi_drive=2
When setting hdmi_drive=1 it's working just fine at the right resolution, but then no sound as it's DVI.
I used the workaround with mode=87 and then resolution is detected as 1360x768@60hz which is fine, but still a bit strange
jsnathan
Tue Jul 14, 2020 10:13 am
I have tried the following it worked
hdmi_group=2
hdmi_mode=86
prak_s
Wed Jul 22, 2020 11:21 am
Thanks jhihn, I tried your suggestion and it worked like a charm for me.
SiD7133
Mon Aug 17, 2020 7:43 am
It was fine when i flashed the '2020-05-27-raspios-buster-armhf' on my pi 4. Problem started occurring after update.
sudo apt full-upgrade
and after rebooting got the error like 'Input signal Out of range' in my VGA monitor (am using a HDMI-VGA adapter)
Had to set the config file to
framebuffer_width=1366
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=82
to solve the issue , but the display seems to be stretched which was not the case before update.
ober
Authorised Reseller
Authorised Reseller
Tue Aug 18, 2020 10:08 pm
Well, I have the same model of Acer monitor with 1366x768 and I have failed to make it display at all. Not even the rainbow screen during the boot and the desktop. So basically I need to edit the config.txt from the microSD from another computer.
For my case, if I use the May 2020 version of Raspberry Pi OS, there is still no display. I need to use a micro HDMI to VGA adapter and use VGA cable for the monitor, or connect the Raspberry Pi 4B to another monitor with different resolution and update the Raspberry Pi OS with
sudo apt update
This solves my problems :) I am still getting 1280x720, though.
BTW, I refer to this video earlier: https://youtu.be/S4Qn_mzdmrs.
Ober Choo
Cytron Technologies, Malaysia
Simplifying Digital Making
sudhiruu
Sat Aug 22, 2020 5:32 am
I have tried everything described here. Still, the monitor displays "no signal input".
i have been using Debian (64 bit structure) for five years. I am a beginner on Raspberry pi.
I bought Raspberry pi 4 (8 GB) kit yesterday and an HDMI to VGA converter. I have tried to connect my monitor but could not.
I have HCL lcd monitor 1366*768 60 Hz vga1. I have edited congig,txt many times with hundreds of combinations described here. Could anyone find a solution?
RedMarsBlueMoon
Sat Oct 17, 2020 2:07 am
I just wanted to chime in to say that this one worked for me too.
hdmi_group=2
hdmi_mode=87
pidd
Sat Oct 17, 2020 3:40 am
Some HDMI to VGA converters require too much current from the HDMI socket. What model is it?
LTolledo
Sat Oct 17, 2020 3:57 am
forcing a resolution to 1360 x 768 worked for me
Some people be like:
6by9
Mon Oct 19, 2020 9:38 am
Deadweasel
Tue Nov 10, 2020 3:20 pm
hdmi_group=2
hdmi_mode=87
Confirming this works like a charm for RPi4 and Asus VT168 touch display, which despite the explicit size declaration is still only 1360x768, but working precisely as hoped-for.
This info is also posted at https://www.raspberrypi.org/documentati ... i4-hdmi.md
This community rocks; I've been struggling with this issue since I first got the RPi4, and I was concerned there was some kind of irreversible hardware bug. :D
ON5MF
Sat Nov 14, 2020 8:11 pm
It's a pity this problem still exists in the Pi400 also.
Swap_File
Thu May 06, 2021 12:03 am
On my older install of raspbian 1366x768 works great, if I run apt get upgrade, it breaks my monitor's native resolution.
Working:
sudo /opt/vc/bin/vcgencmd version
May 11 2020 19:00:52
Copyright (c) 2012 Broadcom
version 21bfdeee3a6ea823e2113b983390acd1eec8edfb (clean) (release) (start_x)
 tvservice -m DMT -v 2
Group DMT has 4 modes:
           mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
           mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
           mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
  (prefer) mode 81: 1366x768 @ 60Hz 16:9, clock:85MHz progressive
After sudo apt update:
Feb 25 2021 12:11:39
version 564e5f9b852b23a330b1764bcf0b2d022a20afd0 (clean) (release) (start_x)
Group DMT has 3 modes:
I'll be staying on 21bfdeee3a6ea823e2113b983390acd1eec8edfb until this is fixed.
