count_wakula
Compiling Mullvad VPN app on Pi 4B
Thu Feb 27, 2020 9:28 am
I am trying to compile the open source Mullvad VPN app on Pi 4B running DietPi (a raspbian 9.0 distribution).
They do include instructions on their github page:
https://github.com/mullvad/mullvadvpn-a ... /README.md
However, I don't feel confident enough in my linux CLI skills to experiment with this.
As I see it, I have to do the following steps to compile and install Mullvad VPN:
1. Check out from git repo
git clone https://github.com/mullvad/mullvadvpn-app.git
cd mullvadvpn-app
git submodule update --init
2. Get all build dependencies
# For building the daemon
sudo apt install gcc libdbus-1-dev
# For building the installer
sudo apt install rpm
3. Get/install rust
Just download and unpack the node-v12.xxxx.tar.xz tarball and add its bin directory to your PATH.
I am actually not sure how to go about this.
4. Build the application
./build.sh --dev-build
As I understand, this should create a ARM deb file, which I then install.
How do I get it run at boot? Do I need run something similar to this:
For Raspbian:
sudo useradd -rm mullvad -G pi -s /usr/sbin/nologin
For DietPi:
sudo useradd -rm mullvad -G dietpi -s /usr/sbin/nologin
Do I need to create a systemd service?
Any additional guidance would be greatly appreciated. I've compiled headless applications on DietPi before, but only with the help of in-depth, step by step guides for Raspbian/DietPi.
Re: Compiling Mullvad VPN app on Pi 4B
Thu Feb 27, 2020 1:00 pm
cd mullvadvpn-app
3. Get/install rust
For Raspbian:
For DietPi:
Where does it state it is suitable software for ARMHF Linux ??
https://mullvad.net/en/download/
Works on Ubuntu 16.04.2+, Debian 9+ (64 bit only) Linux
https://mullvad.net/en/help/install-mullvad-app-linux/
count_wakula
Sat Feb 29, 2020 11:50 am
Their binaries are for x64, that's why I wanted to compile a version for ARM.
Sat Feb 29, 2020 1:28 pm
You would need to Build from Source Code if it is available, the Binaries appear to be pre-compiled for x86-64....
...personally would find an alternative !!
count_wakula
Wed Mar 04, 2020 6:12 pm
That's what I am trying to figure out.
The linked pages described compiling not installing. As I understand it the instructions allow you to compile a ARM .deb that can then be installed on DietPi/Raspbian.
There are very few reputable alternative that allow port-forwarding at the VPN level.
