aaa801 wrote:didnt the v2 have some swaped gpio pins, you sure its hooked up correctly?
that is correct. the modul was found on ic2-bus 1 on address 0x56 (before i bind the device to the driver).
sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- 56 -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
when i used i2cset / i2cget - i can read the secound register of the chip and i mean it works perfectly.
sudo i2cset -y 1 0x56 0x08
sudo i2cget -y 1 0x56
0x27
0x29
0x30
0x31
when i bind the device on the driver
sudo bash
echo rv3029c2 0x56 > /sys/bus/i2c/devices/i2c-1/new_device
exit
i see follow ("UU". Probing was skipped, because this address is currently in use by a driver.)
sudo i2cdetect -y 1
50: -- -- -- -- -- -- UU -- -- -- -- -- -- -- -- --
and i ckecked also
cat /proc/devices | grep rtc
254 rtc
ls -l /dev | grep rtc
crw------- 1 root root 254, 0 Dez 17 03:22 rtc0
...but i become follow error on next command.
sudo hwclock -r --debug
hwclock from util-linux 2.20.1
Using /dev interface to clock.
Last drift adjustment done at 1355708249 seconds after 1969
Last calibration done at 1355708249 seconds after 1969
Hardware clock is on UTC time
Assuming hardware clock is kept in UTC time.
Waiting for clock tick...
hwclock: select() to /dev/rtc0 to wait for clock tick timed out: Datei oder Verzeichnis nicht gefunden
...synchronization failed
