I have a project for educational purpose, the project runs a 3 step motors with 3 axes (X,Y,Z)
the motors will be running via Arduino ( i tried to run the motors with the old fashion way with Arduino and it worked perfectly fine ) my problem is how can i run those motors using the Raspberry PI 4, (i did installed Arduino in the RPI 4 and am connecting the Arduino and the RPI 4 via USB cable )
do i have to run a commande or something using python so it can run the Arduino code ? if yes can you enlighten me with it it would much appreciated
if not can you propose a solution for me ?
and thank you
