addms
MCP3008 voltage values are 2x larger than expected
Wed Feb 26, 2020 9:02 pm
I'm currently using a MCP3008 and my analog input is coming from an arbitrary waveform generator. The generator is producing a sine wave with a peak to peak voltage of 0.5 and an offset of 0.5 volts. I would expect the MCP3008 to get values between 0.25 and 0.75, but instead I'm getting between 0.5 and 1.5.
Here is the code I'm using:
import os
import time
import busio
import digitalio
import board
import adafruit_mcp3xxx.mcp3008 as MCP
from adafruit_mcp3xxx.analog_in import AnalogIn
# create the spi bus
spi = busio.SPI(clock=board.SCK, MISO=board.MISO, MOSI=board.MOSI)
# create the chip select (cs)
cs = digitalio.DigitalInOut(board.CE0)
# create the mcp object
mcp = MCP.MCP3008(spi, cs)
# analog input channel on pin 0
chan0 = AnalogIn(mcp, MCP.P0)
while True:
	print("Voltage: ", chan0.voltage)
	time.sleep(0.1)
Pictures of the setup are here: https://imgur.com/a/GtUIoQ7, sorry if they're not clear, I'll take more if necessary.
Thanks in advance!
B.Goode
Re: MCP3008 voltage values are 2x larger than expected
Thu Feb 27, 2020 8:51 am
Welcome to the Raspberry Pi forums.
import os
import time
import busio
import digitalio
import board
while True:
	time.sleep(0.1)
Thanks in advance!
As a comparison for troubleshooting purposes, the gpiozero Python library has built-in support for the mcp3008 family of ADC chips.
Perhaps a quick test would help discriminate between software and hardware/wiring issues.
https://gpiozero.readthedocs.io/en/stab ... entiometer
addms
Thu Feb 27, 2020 9:15 pm
Hi thanks. I did use the following code using the gpiozero library and got the same numbers:
import gpiozero
import time
m = gpiozero.MCP3008(channel=0)
while True:
	print(m.voltage)
	time.sleep(0.1)
PeterO
Thu Feb 27, 2020 9:26 pm
What do you have connected to Vref ?
IF your signal source was 0.5V peak (not peak to peak) and you had 3.3V (instead of 5V) conected to Vref , then I think you would see 0V to 1.5V readings.
PeterO
B.Goode
Thu Feb 27, 2020 9:55 pm
import gpiozero
import time
while True:
	print(m.voltage)
	time.sleep(0.1)
Also, wondering if you should be using the value attribute (scaled between 0 and 1) rather than voltage (scaled between 0 and max_voltage)?
addms
Fri Feb 28, 2020 2:53 pm
So I tried using the value attribute, but the values are still 2x larger, as anything above 1.65V (3.3/2) returns a value of 1.
I have 3.3V connected to Vref as that's what every tutorial did. I think my signal source is in fact 0.5V peak to peak, here are some photos of the waveform generator: https://imgur.com/a/GQKdR3x
JohnsUPS
Tue Mar 03, 2020 12:25 pm
Have you tried applying a constant DC voltage to validate the ADC and your code? If that comes back as accurate, then your readings are being based on how the ADC is seeing the sine wave. Maybe you need to look into synchronizing the ADC reads with a zero crossing detector (with delay to catch the peaks, not the crossings ;)
