Good day tech support! I have a problem with combination of Raspberry Pi 4 Model B and WTWare of latest version. If to be short I wrote configuration of WtWare which can only loads through Ethernet and doesn't have configuration file (only boot file). And then i tried to launch it but nothing happened. No ethernet connection, no IP-address, no video-output. Nothing.
So the only mode WTWare is working is when you put full configuration and files for booting together on SD-card. But sadly it completely destroys the idea of updating and managing thin-clients through ethernet.
Can you please try to help me with such a problem? The only signs of life that RB Pi4 Model B shows when it has boot file on card it is 5 flashes of green led and then waiting for 5 seconds. After waiting it begins flashing again.
Thanks in advance!
