JoeyJoeJo
Battery pack
Sun Dec 23, 2012 7:10 am
According to Wikipedia, the raspberry pi can accept power input from the GPIO pins. Is that true? If so, and I could hook up a lithium battery to the GPIO pins, could it be charged via the pi's micro USB port?
malakai
Re: Battery pack
Sun Dec 23, 2012 7:27 am
Yes everything on the Wiki is true :)
Yes depends on the battery I suppose
Yes but not at the same time it's powering the Pi and it actually depends on how much power it needs to be charged
texy
Re: Battery pack
Sun Dec 23, 2012 8:41 am
JoeyJoeJo wrote:According to Wikipedia, the raspberry pi can accept power input from the GPIO pins. Is that true? If so, and I could hook up a lithium battery to the GPIO pins, could it be charged via the pi's micro USB port?
That is the opposite way to the way things normally run with the pi - it is usual to power the pi by the micro usb port, and to supply (limited) power to peripherals via the GPIO port.
Not sure what you are expecting if you want to power and charge the same battery via the pi?
Texy
joan
Re: Battery pack
Sun Dec 23, 2012 10:11 am
Yes, you can power the Pi from the P1 pins (+5V and ground).
No, don't connect a lithium battery directly to the pins, you need to supply 5V which the battery probably doesn't. Use a UBEC or similar to convert the battery output to 5V.
Charge the battery via the micro USB? No.
