DeadlineX
hdparm service is missing
Sat Feb 22, 2020 2:03 pm
Hi, everyone,
I’ve installed hdparm package and hdparm is working. But I’ve not understood how to apply its config on system startup. I’ve added appropriate section in config, but AFAIU there should be a service which will launch hdparm.
But the hdparm.service is absent. This is what I’ve got:
 pi@raspberrypi:~ $ sudo service hdparm restart
Failed to restart hdparm.service: Unit hdparm.service not found.
Am I missing something?
Thank you.
LTolledo
Re: hdparm service is missing
Sat Feb 22, 2020 2:25 pm
carefully read and fully understand what is written on the link provided below.
https://linux.die.net/man/8/hdparm
Some people be like:
DeadlineX
Sat Feb 22, 2020 3:45 pm
OK, I’ve read it. That’s the man page for hdparm. Nothing more. Do you wish to say that there is no service and service is not required? Or what? All I wish to do is to spin down the HDD after some predefined time. I’ve set this section in /etc/hdparm.conf
dev/sda {
write_cache = on
spindown_time = 120
Is this all I should do?
epoch1970
Sat Feb 22, 2020 4:53 pm
I think LTolledo means that one: https://manpages.debian.org/buster/hdpa ... .5.en.html
1. There is no init script, it is run by udev
2. There is a typo in your config file ("/dev/", not "dev/")
DeadlineX
Sat Feb 22, 2020 7:25 pm
Thank you!
As for the typo - it’s a copypasting error. Everything is written correctly in the config file.
I’ve used this command:
 /usr/lib/pm-utils/power.d/95hdparm-apm resume
and it has returned nothing. So, should I consider it, as “ok”?
Also I have yet a couple of questions:
1. The response of hdparm -y /dev/sda is:
 root@raspberrypi:/home/pi# hdparm -y /dev/sda
/dev/sda:
 issuing standby command
SG_IO: bad/missing sense data, sb[]:  70 00 01 00 00 00 00 0a 00 00 00 00 00 1d 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
HDD spins down nevertheless, and is in standby mode unless I’ll awake it accessing its content. How should I consider this situation? Is this a USB-SATA controller incompatibility, or what? May I simply ignore this error?
2 Where can I get more info about -B option values? I’d like to know how these values correspond to standby delay in seconds? Is it just the same, as “spindown_time” parameter in the config file?
Thank you.
epoch1970
Sun Feb 23, 2020 11:19 am
I can’t help about hdparm itself.
That utility was in full bloom when hard drives parking their heads sounded like a ping-pong ball had dropped...
I don’t believe hdparm is necessary any longer, firmwares built into modern drives are much more sophisticated than in the olden days.
If your drive goes into sleep mode within a reasonable delay after you dismounted all volumes, the firmware works ok.
Consider using a filesystem automounter instead.
DeadlineX
Re: hdparm service is missing [CLOSED]
Sun Feb 23, 2020 6:16 pm
I don't like the idea to dismount volumes. It will make the disk inaccessible, what is definitely not what I want to get.
At present I've resolved the standby problem. Disk goes sleeping in 10 min as it is defined in the config. That's just what I'd like to get.
OK, I'll take a look, thank you.
Return to “Raspberry Pi OS”
