Sorry if I am posting this in the wrong place, but I have been stuck for a while trying to figure out what is going on. I am trying to setup a Zero W headless but I keep running into different errors its weird, I will describe my entire process below.
Download Raspbian Buster Lite. Download balenaethcer app and flash the OS onto the SD card. Now I open my SD card [boot(D:)] and create two files inside of boot, wpa_supplicant.conf and ssh. Then I download putty 64-bit msi installer and install putty onto my pc. Then I put my SD card into the Pi and power the pi. Open the putty and put in raspberrypi.local into the host name (i have also used the IP address for the Pi but that gives the same error). Then the putty terminal window opens and there are no prompts in the window to login. Then after about 5 seconds I get an "Network error: Software caused connection short".
I have uninstalled and reinstalled everything that was downloaded multiple times.
Also I have run into other errors: During my first attempt I actually logged in changed my host name and password and enabled VNC and then opened RealVNC and got a hostname and password error, which made no sense (after doing this I reflashed my SD card and tried to restart the process). I seem to get a different error every time, but now I am stuck at the putty failure. If there is any help or anything I should to fix this, it would be greatly appreciated. This is the first experience with the Pi and so far I keep getting stuck.
Thanks for any help and sorry if I posted this in the wrong place.
