Morkelon
Docker questions
Tue Feb 18, 2020 12:29 am
Hi all,
I'm trying to install Docker on a Raspberry PI 3 B.
I followed the general steps here:
https://docs.docker.com/install/linux/docker-ce/debian/
and by the time I run the Hello World container, I read that to install Docker Engine in Raspbian you must use the convenience script.
The thing is, after running these commands:
$ sudo apt-get install docker-ce docker-ce-cli containerd.io
$ sudo docker run hello-world
The hello world run fine.
I already uninstall it and I'm going to install it using the convenience script but I wonder:
what's the problem with installing it using the normal way? Since I only run a Hello world container, I want to know what's the explanation about installing it the normal way in Raspbian.
I also want to know why the convenience script works. What's the difference?
Thank you in advance.
topguy
Re: Docker questions
Tue Feb 18, 2020 12:19 pm
Docker provides convenience scripts at get.docker.com and test.docker.com for installing edge and testing versions of Docker Engine - Community into development environments quickly and non-interactively.
You will get newer versions than the one in the Raspbian repository.
