bonzadog
Partitioning + Formating a USB HDD
Fri Feb 14, 2020 11:15 am
Sometime the booting from a USB HDD will be released.
I want to use a fast 320GB HDD for boot at a later date and for data usage now.
Perhaps even using it to page virtual storage.
So I want to create a boot partition and a data area(s) . For Rpi 3 and Rpi4 4GB.
The HDD will be used by the RPi3 and RPi4 .
Can someone kindly give me some tips?
Many thanks
Re: Partitioning + Formating a USB HDD
Fri Feb 14, 2020 12:39 pm
Many thanks
Why not just clone your current SD Card to the USB Drive, then it will be ready in the future ?
Retired disgracefully.....
bonzadog
Fri Feb 14, 2020 2:01 pm
I must partition + format the HDD first. I am looking in Internet to find out the best way to do that and I do not wish to clone but do everything from "first principles". Sorry, I should have made that clear. I assume there must be at least two partitions, one for the boot system and swap area and , say, two partitions for the data. To access the data areas I must then mount them. I was wondering is there s anything I must do that is specific to the RPi's
Fri Feb 14, 2020 2:05 pm
I must format the HDD first. I am looking in Internet to find out the best way to do that and I do not wish to clone but do everything from "first principles". Sorry, I should have made that clear.
gparted is in repositories to create partitions / format:
https://gparted.org/
bonzadog
Fri Feb 14, 2020 2:09 pm
Just found that. I need tow to read up on what ext2 / ext3 / ext4
fat16 / fat32
hfs / hfs+
linux-swap
does and what sizes ( hence my question)
Fri Feb 14, 2020 2:22 pm
fat16 / fat32
hfs / hfs+
linux-swap
Standalone Raspbian Buster latest release has a 256MB FAT32 Boot Partition, whilst the rest of the space is EXT4, when creating a bottable SD Card
If you use NoobS or PiNN to install, well:
https://github.com/raspberrypi/noobs/wi ... -explained
bonzadog
Fri Feb 14, 2020 2:33 pm
No I do not want to use NOOBS etc. all from first principles...
HawaiianPi
Fri Feb 14, 2020 4:22 pm
Raspbian Buster with desktop includes the SD Card Copier utility which will clone your SD card to another device (even a USB HDD), and it handles different sized devices gracefully (it just works). You can use that to copy your SD card to your HDD.
ejolson
Fri Feb 14, 2020 4:49 pm
In the end you will probably want three MBR-style partitions: A tiny partition with ID c W95 FAT32 (LBA) about 256MB, a swap partition about 2 times the size of physical RAM (for example 4GB) with ID 82 Linux Swap and a huge root partition consisting of the remaining disk with ID 83 Linux. Format the tiny partition as FAT32, the swap partition as swap with label SWAP and the root partition using whatever Linux filesystem sounds good such as ext4, btrfs, xfs, reiserfs or jfs. I would also give the filesystem on the huge partition a label reflecting a vanity name for the drive or computer the drive will be connected to, for example, BONZ1 comes to mind.
Now mount a Raspbian formatted SD card on your Linux computer and copy the files in the boot and root partitions of the SD card to respective partitions on the HD using the appropriate tar commands. Don't forget to clear the umask flags before doing the copy.
At this point you may need to fiddle with the cmdline.txt on the SD card to mount root from the HD and /etc/fstab on the HD to mount the swap and remount the root read write.
B.Goode
Fri Feb 14, 2020 5:56 pm
and previously -
Your determination to learn by doing is admirable.
But the images of the Raspbian Operating System distributed by Raspberry Pi are effectively themselves 'cloned' from the RPi development/packaging system. They contain implicit information about the partitions that will be created on the target media when the image is 'flashed' to that media.
How far back does your search for 'first principles' take you... ? Will you be building an Operating System (kernel, utilities and applications) from source?
bonzadog
Sat Feb 15, 2020 9:56 am
and previously -
Building an OS: No, but I would love to try that out. Perhaps I could look at that much, much later. In fact writing a primitive OS system does appeal to me. Ages ago I wrote some drivers in assembler + HAL/S but had worked in high level languages mostly.
I now want Boot partition, swap area, two Partitions for FAT32 data and one partition for NTFS. I understand that I would meed to load a NTFS drive on the RPi to cope with Win files.
Ideally I would like multiple boot partition, so I can select which OS I wish to use....but that would be a "nice to have" feature. But I want to get a single boot system up a running before I attempt this.
Since retirement, the RPi4 keeps me active and I like working with the Rpi.
Thanks for the assistance.
Return to “Beginners”
