Ncm123
HTML5 games lagging on pi
Tue Feb 11, 2020 2:02 pm
Hi
I am trying to build a gaming pc for my 5 year old son with the raspberry pi. I wish to make a few html5 games teaching typing , math which will play without lag in the raspberry pi.
I tried playing a few games made in construct 3 but they lagged. Can anyone help me with advice on how to make html5 games that dont lag on the pi?
Thanks!
topguy
Re: HTML5 games lagging on pi
Tue Feb 11, 2020 2:10 pm
Which browser do you test with ?
Does resizing the browser window reduce the "lag" ? ( I interpret "lag" as a low refreshrate/stuttering in the UI )
Ncm123
Tue Feb 11, 2020 2:37 pm
I tested on chrome. I am using raspberry pi 4. Lag meaning the frame rate is low of the game and stuttering happens.
Ncm123
Fri Feb 14, 2020 4:40 am
Well yesterday, I tried playing this game on chrome in my Pi4 machine. It hanged the PI.
https://html5games.com/Game/Element-Blo ... 6eef2fb5ed
Is there any list online which has list of html5 games working on the pi?
I even tried playing games on the scratch website - even those games lag a lot.
clicky
Sat Feb 15, 2020 7:02 pm
Something else is wrong. I've just started it on my Pi4 and it works quite well... Maybe not 60fps but works with decent framerate...
kerry_s
Sat Feb 15, 2020 7:50 pm
i tried that block 1, it is laggy, but if you enable "GPU rasterization" the force in all layers, in chrome://flags it's a little better. also your going to have to raise the gpu split(performance in the config) mines at 128 right now, you could try that or go higher, i don't recommend more than 256 tops. normally mines at 96 and i'm running gnome, i raised it to try the game. :D
it depends on the game, some run perfectly fine, others don't seem optimized or they have a lot of things going on(aka: trying to be to fancy).
thanks for the heads up on the site though, going to use for my niece.
Ncm123
Mon Feb 17, 2020 12:42 pm
Hi
I am using raspberry pi 4 with one gb ram. Do you think 4 gb ram would make it better? If yes, I will obtain one.
topguy
Mon Feb 17, 2020 1:41 pm
You should check how much of the current 1GB you are using before you splash out on a new Pi.
"htop" is a nice command to install, shows the memory usage a bit better than normal "top".
kerry_s
Mon Feb 17, 2020 4:00 pm
i got those games going pretty good.
memory split is set at 160
dropped my resolution from 1920x1080 to 1280x800
turned on all the gpu goodies.
Ncm123
Wed Mar 04, 2020 12:18 pm
For us also once we drop the resolution it works well.
I am trying to build a game which will run on full screen in a browser. Can I reduce the resolution only for the browser instance?
topguy
Wed Mar 04, 2020 12:32 pm
You can not have one window in a different resolution than the rest of the desktop. ( if I understand your question correctly )
Return to “Gaming”
