pshangguan
Setup Port Forwarding on Pi 4 Error
Mon Feb 10, 2020 10:45 pm
I have a raspberry pi 4 at home behind a router(netgear nighthawk) and I want to run a command to setup port forwarding on the router for port 11911/TCP. The internal IP of the PI is 192.168.1.20 and I tried to use "upnpc" as:
[email protected]:~ $ upnpc -a 192.168.1.20 11941 11941 TCP
upnpc : miniupnpc library test client, version 2.1.
(c) 2005-2018 Thomas Bernard.
Go to http://miniupnp.free.fr/ or https://miniupnp.tuxfamily.org/
for more information.
List of UPNP devices found on the network :
desc: http://192.168.1.1:5000/Public_UPNP_gatedesc.xml
st: urn:schemas-upnp-org:device:InternetGatewayDevice:1
Found a (not connected?) IGD : http://192.168.1.1:5000/Public_UPNP_C3
Trying to continue anyway
Local LAN ip address : 192.168.1.20
GetExternalIPAddress failed.
AddPortMapping(11941, 11941, 192.168.1.20) failed with code -3 (UnknownError)
I am not sure what is wrong with this...
Thanks,
Philip
pcmanbob
Re: Setup Port Forwarding on Pi 4 Error
Tue Feb 11, 2020 11:26 am
Hi.
Port forwarding is normally done on the router its self using the router web access / setup page,
you need to read the user manual for your router as you may need to setup a service before you can do the port forwarding.
using UPNP will only work if a service has already been configured for it to use.
pshangguan
Sat Feb 15, 2020 2:48 am
I understand I could configure the router by using the browser. But I want to explore a command method to set it up so that when anyone uses the pi board and turned it on at home, it will configure the port forwarding on his/her home router automatically. I can find the router's external IP using "curl" on the board, I just need to find a way to set the port forwarding on the router using command so that I can do it from a startup script.
Any idea will be appreciated!
pcmanbob
Sat Feb 15, 2020 10:23 am
Well not all routers will support it out of the box and even those that do may have the function turned off, Did this on my router to preventive programs forwarding ports to the outside world without my knowledge.
davidcoton
AFAIK, the commands required will be different for every make (and possibly model) of router.
Signature retired
