rego21
bcm2835-unicam driver and ov5647
Sun Feb 09, 2020 4:36 pm
Hi all!
I'm trying to learn more about V4l2, so while searching about this I found the bcm2835-unicam driver. And I'm trying to use it along with the OV5647 Camera. So far what I have done:
- used the overlay provided --> ov5647 overlay
- modrpobe both bcm2835-unicam and ov5647 modules
However, the system doesn't create a /dev/video0 and cant output video...
Can anyone help me with this or maybe I'm missing something.
Setup:
Raspberry Pi A+ v1.1
Thank you all!
UPDATE: When running modprobe ov5647 dmesg outputs the following : probe of 0-0036 failed with error -5
6by9
Re: bcm2835-unicam driver and ov5647
Sun Feb 09, 2020 9:46 pm
Please don't spam multiple threads and then ask the same question on a new thread as well.
Youve loaded modules but haven't provided any device tree configuration for them, therefore they sit there dumbly and are unable to load.
Add "dtoverlay=ov5647" to config.txt and the kernel will load the matching modules for you, and they will then have the required configuration. As you're on a Pi 1A+ you'll need to add "i2c_pins_28_29=1" to the end of the line as the camera is connected to those GPIOs instead of the default 44&45.
See https://github.com/raspberrypi/linux/bl ... verlay.dts for the contents of that overlay.
rego21
Mon Feb 10, 2020 5:44 pm
Hii,
Sorry I forgot to delete them!
Its working, thanks for the help I was missing the i2c pins. Thanks once more!
Mrlbppy
Thu Mar 26, 2020 12:46 pm
I need your help. I have a problem. When I run 'sudo modprobe bcm2835-unicam' , I get some errors:
libkmod: ERROR ../libkmod/libkmod-config.c:656 kmod_config_parse: /etc/modprobe.d/▒laCklist,rt,8xxxu.conf line 1: ignoring bad line starting with 'import'
Do you know why?
Return to “Camera board”
