You don't say what you have downloaded but RPi images are not ISOs and you cannot expect a generic ARM build to run on a RPi. You require a specific build for a RPi. Suggest you have a read through https://www.raspberrypi.org/forums/view ... 5&t=257909guerlando wrote: ↑Fri Feb 07, 2020 9:29 pmI tried downloading the Windows 10 IoT core ISO and dd'ing it to an SD card but it won't even boot. The image is ARM32 but I guess it should run on ARM64. I don't have access to Windows 10 to use the Windows 10 dashboard. So how can I flash the ISO to an SD card?
Not quite, certainly not formally. But the support for 3B+ is patchy, the support for 3A+ & 4B is non-existent.
