TPessoa
PLC Console RPi
Mon Feb 03, 2020 12:13 pm
Hello all,
I've been searching for options to replace an HMI console for a rpi and a 7'' screen.
Is this feasible?
Do I need a RS485/Modbus module to communicate PLC <-> RPi?
Can I make the RPi "understand" what the PLC is sending and put it in some kind of GUI for the operator to read?
Hope I'm making myself understood...
josar
Re: PLC Console RPi
Sun Mar 22, 2020 3:17 pm
In general, yes it is.
What PLC are you using? If it has Ethernet port, it might be possible to read data from it with a plain Raspbery Pi.
If it has only RS485, then you'll need some HAT or USB converter to use the RS485 bus.
Still I wonder what PLC are you using.
ranpitime
Re: PLC Console RPi
Fri Mar 27, 2020 5:45 am
I would use CODESYS on Raspberry PI, ( https://store.codesys.com/codesys-contr ... pi-sl.html)
sure this is a full plc runtime - but you could connect by Modbus or which fieldbus you want to the plc.
HMI/Visualisation could be done by the 7" fullscreen in the Raspberry PI browser.
If need you could execute the local webvisu via CODESYS Automation server ( https://store.codesys.com/cas.html) - from outside your network.
So pretty easy to make it accessible to your smartphone, without having huge configuration efford.
Regards
ranpitime
