Zackeos
Help with Build a robot buggy project
Sun Feb 02, 2020 10:11 pm
When I follow the steps and run the code:
from gpiozero import Robot
robby = Robot(left=(7,8), right=(9,10)
And the in the shell run:
robby.forward()
I get the error:
NameError: 'robby' is not defined
Can anyone help?
B.Goode
Re: Help with Build a robot buggy project
Mon Feb 03, 2020 6:22 am
robby.forward()
I get the error:
Can anyone help?
The robby.forward() function call is a Python statement that must be part of the same Python script as the one that created an instance of Robot()
Using that statement from a separate shell is a complete misunderstanding of what is possible
Your Python script seems to be missing a closing bracket )
B.Goode
Mon Feb 03, 2020 2:46 pm
Subsequent followup -
Possibly the resource you are using is https://projects.raspberrypi.org/en/pro ... -a-buggy/3
So maybe it is a python shell you are using, not a system command line shell?
The inability to use the robby object is probably a consequence of the typing error when you tried to create it.
rifle37
Thu May 07, 2020 2:17 am
robby.forward()
I get the error:
Can anyone help?
I am having this same problem. The syntax is correct and it even executes in mu. Unfortunately I can't get it to work in the Python shell. Does anyone know of a way to fix this problem?
scotty101
Thu May 07, 2020 8:30 am
Same problem as above, have you tried the suggested solution? Don't try to run the commands from the command shell or python shell just add them to the python script.
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
B.Goode
Thu May 07, 2020 8:32 am
Welcome to the Raspberry Pi forums -
robby.forward()
I get the error:
Can anyone help?
The answer remains the same -
JV1
Tue May 19, 2020 11:40 am
Hi, we are having the same problem. I have checked syntax and all is correct as per instructions. Does anyone have a solution to this one yet? python code runs in mu. get the same error as others in the terminal as below
pi@raspberrypi:~ $ python
Python 2.7.16 (default, Oct 10 2019, 22:02:15)
[GCC 8.3.0] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> robby.forward()
File "<stdin>", line 1, in <module>
NameError: name 'robby' is not defined
really appreciate some help as we are new to this.
B.Goode
Tue May 19, 2020 2:26 pm
>>> robby.forward()
Yes. The solution has been given or referred to repeatedly in this thread.
Fix the broken syntax in the line robby = Robot(left=(7,8), right=(9,10)
Then you should find that the object 'robby' IS defined and no error will ensue.
Hint: count the brackets...
rpiMike
Tue May 19, 2020 2:55 pm
The 'Build a robot buggy' project has bad instructions !
https://projects.raspberrypi.org/en/pro ... -a-buggy/2
It tells you to write the following code in 'mu' :
robby = Robot(left=(7,8), right=(9,10))
Then in a terminal window it tells you to enter Python then robby.forward() which will not work as robby is created in a different environment.
Either enter robby.forward() in the lower section of 'mu' next to >>> or just add it as the third line of code:
robby.forward()
I've twice submitted feedback on this tutorial, but not fixed yet.
PiGraham
Tue May 19, 2020 3:00 pm
They are Buggy instructions :lol:
dirkjefferson
Fri Jul 17, 2020 3:02 pm
Hi.
I have the same problem.
Syntax is correct - right no. of brackets.
Running the command in mu, not python.
Nothing doing.
I think the wiring is all correct - we have a 3b+, and the board has "J8" printed on it, and I've found the schematic for a 3b+ J8 board.
Sounds like there may be something else going on here - the syntax isn't the issue.
Any other suggestions would be greatly appreciated - our lovely father/son project is gathering dust on a tray!
