I'm a not too experienced Raspberryuser, managed to get temp sensors working and putting dada in database etc. Mainly by copy-paste but starting to understand a bit how it works.
To get some sensors for air-quality measuring, I found some code to to this and after some fumbling around it works. MQ-7 sensor, MCP3008 etc.
I get "exact" data for LPG, CO, Smoke.
The necessary input for MQ measurement I got from:
https://tutorials-raspberrypi.com/confi ... nsor-mq-x/
my problem is: I want to get these data from python script via MySQL into a table and that's where I don't seem to advance a lot.
I created a table:
[img]Schermafbeelding 2020-02-02 om 17.15.30.jpg[img]
and did many attempts to create lines to put the data in table "GasData2"
Here's my script till now...the first part works (displaying data) the second part shows me that the data are not put in Dbase.
Thx if someone can give me the code that accesses the table!.
GasS2SQL.py
#hersteld van GasS1SQL.py.save 26-01
#ombouw example.py naar Gassensor.py 17012020 voor SQL
from mq import *
from MCP3008 import MCP3008
import logging
import os
import glob
import MySQLdb
from time import strftime
#logging.basicConfig(filename="logexample1.log" , level=logging.DEBUG)
#adc = MCP3008()
#value = adc.read( channel = 0 )
#print("Anliegende Spannung: %.2f" % (value / 1023 * 3.3) )
#oude deel van example.py
from mq import *
import sys, time
# Variables for MySQL
db = MySQLdb.connect(host="localhost", user="root",passwd="raspeter50", db="temp_database")
cur = db.cursor()
try:
print("Press CTRL+C to abort.")
mq = MQ();
#logging.debug("MQ?: {}".format.MQ())
while True:
perc = mq.MQPercentage()
sys.stdout.write("\r")
sys.stdout.write("\033[K")
sys.stdout.write("LPG: %g ppm, CO: %g ppm, Smoke: %g ppm" % (perc["GAS_LPG"], perc["CO"], perc["SMOKE"]))
datetimeWrite = (time.strftime("%Y-%m-%d ") + time.strftime("%H:%M"))
#print ("\r")
print "CO"
#%g = percLPG
#%g = percCO
#%g = percSmoke
print datetimeWrite
sql = ("""INSERT INTO GasData2 (datetimeCO, percLPG, percCO, percSMOKE) VALUES (%s,%s,%s,%s)""",(datetimeWrite,perc))
sys.stdout.flush()
time.sleep(1)
try:
print "Writing to DB..."
cur.execute(*sql)
db.commit()
print "weggeschreven"
except:
db.rollback()
print "lukt niet naar DB te schrijven"
except:
print("\nAbort by user")
code]
