MarkMB1
USB Speaker doesn't appear unless plugged in and out
Tue Jan 28, 2020 10:38 pm
Hi i am just wondering is there a way to get the raspberry pi to detect the usb speaker on boot. If the pi is rebooted and the speaker is plugged it, it will not work or even appear until it is plugged out and back in again.
Botspot
Re: USB Speaker doesn't appear unless plugged in and out
Wed Jan 29, 2020 2:06 pm
Try disabling the Pi's internal sound card.
sudo mousepad /boot/config.txt
Add a # before dtparam=audio=on, and below it add dtparam=audio=off.
Like this:
#dtparam=audio=on
dtparam=audio=off
Save the file (Ctrl+S), then reboot. See if that work. If not, what does the command lsusb say?
Ever wished you could "open" a RaspiOS .img file? Well now you can! I've developed Pi-Power-Tools, the only RaspiOS img editor on the planet.
https://github.com/Botspot/Pi-Power-Tools
Want to try it out?
wget -O - https://raw.githubusercontent.com/Botspot/Pi-Power-Tools/master/update | bash
MarkMB1
Thu Jan 30, 2020 4:59 pm
I just tried that and it didn't work when i execute the command lsusb the USB speaker doesn't appear
However when its plugged out and in again it appears
Bus 001 Device 002: ID 1908:2070 GEMBIRD
Botspot
Thu Jan 30, 2020 5:02 pm
What Raspberry Pi model are you using?
Want to try it out?
MarkMB1
Thu Jan 30, 2020 8:00 pm
Raspberry pi zero w
Botspot
Thu Jan 30, 2020 8:28 pm
Raspberry pi zero w
It appears the Pi zero can shut off power to its usb ports.
https://www.raspberrypi.org/forums/view ... p?t=203261
Try running this command when the usb speaker is plugged in but not recognized:
echo 0 > /sys/devices/platform/soc/20980000.usb/buspower
Want to try it out?
