I have a pi-3b and whenever I attempt to boot it, the red led comes on, and the green led goes into a cycle of active - 3 quick flashes - active.
I have measured the io voltage with a voltmeter and it has full volts on the appropriate pins, so I do not think power supply is the issue.
The 3 different boot cards I have used work with a pi zero and a pi zero w, allowing login on hdmi and using usb for keyboard.
I am assuming there is some sort of hardware problem with the sd-card reader. I wonder what else I might try.
Peter
