Everything worked pretty normal before mid-January. However, I did the 'apt update / app full-upgrade' and noticed that kernel was updated to 4.19.93. Since then, the USB devices are no longer usable. Below is the dmesg output.
If I downgrade the kernel to previous stable versions from November or September (e.g. sudo rpi-update 4b2c270) the issues are gone.
Anything I am missing? I tried also the VL805 000137ad firmware but no change.
[ 37.431597] xhci_hcd 0000:01:00.0: xHCI host not responding to stop endpoint command.
[ 37.447618] xhci_hcd 0000:01:00.0: Host halt failed, -110
[ 37.447630] xhci_hcd 0000:01:00.0: xHCI host controller not responding, assume dead
[ 37.447683] xhci_hcd 0000:01:00.0: HC died; cleaning up
[ 37.457815] usb 1-1: USB disconnect, device number 2
[ 37.457835] usb 1-1.4: USB disconnect, device number 3
[ 37.458119] Unable to handle kernel NULL pointer dereference at virtual address 0000004c
[ 37.458158] pgd = 1d6d2ce3
[ 37.458179] [0000004c] *pgd=80000000004003, *pmd=00000000
[ 37.458215] Internal error: Oops: 207 [#1] SMP ARM
[ 37.458236] Modules linked in: bnep hci_uart btbcm serdev bluetooth ecdh_generic 8021q garp stp llc evdev cx24116 vc4 dvb_usb_dw2102 dvb_usb drm_kms_helper dvb_core v3d gpu_sched brcmfmac brcmutil drm drm_panel_orientation_quirks sha256_generic snd_soc_core cfg80211 snd_compress snd_pcm_dmaengine syscopyarea sysfillrect sysimgblt fb_sys_fops snd_bcm2835(C) snd_pcm rfkill raspberrypi_hwmon snd_timer hwmon snd bcm2835_codec(C) bcm2835_v4l2(C) v4l2_mem2mem bcm2835_mmal_vchiq(C) v4l2_common videobuf2_dma_contig videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev media vc_sm_cma(C) rpivid_mem uio_pdrv_genirq uio fixed ip_tables x_tables ipv6
[ 37.458476] CPU: 0 PID: 68 Comm: kworker/0:2 Tainted: G C 4.19.95-v7l+ #1292
[ 37.458503] Hardware name: BCM2835
[ 37.458538] Workqueue: usb_hub_wq hub_event
[ 37.458585] PC is at dw2102_disconnect+0x24/0x70 [dvb_usb_dw2102]
[ 37.458612] LR is at usb_unbind_interface+0x84/0x26c
[ 37.458633] pc : [<bf95b1fc>] lr : [<c07916e8>] psr: 60000013
[ 37.458655] sp : ef2d7c98 ip : ef2d7cb8 fp : ef2d7cb4
[ 37.458676] r10: dc4bb478 r9 : bf965ac0 r8 : dc4bb420
[ 37.458697] r7 : 00000000 r6 : 00000000 r5 : dc4bb400 r4 : dc4bb420
[ 37.458719] r3 : dbad1000 r2 : 40000093 r1 : 00000000 r0 : dc4bb400
[ 37.458743] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 37.458767] Control: 30c5383d Table: 1ac6e380 DAC: fffffffd
[ 37.458789] Process kworker/0:2 (pid: 68, stack limit = 0xfb3a783a)
[ 37.458811] Stack: (0xef2d7c98 to 0xef2d8000)
[ 37.458832] 7c80: bf95b1d8 dc4bb420
[ 37.458862] 7ca0: dc4bb454 bf965ac0 ef2d7cfc ef2d7cb8 c07916e8 bf95b1e4 ef2d7cdc ffffffed
[ 37.458891] 7cc0: ef2aa878 ef2aa800 00000000 dc4bb400 ef2d7cfc dc4bb420 dc4bb454 bf965ac0
[ 37.458920] 7ce0: 00000000 00000034 dc4bb200 dc4bb478 ef2d7d24 ef2d7d00 c07086f8 c0791670
[ 37.458949] 7d00: 00000007 efa63830 dc4bb420 c106f97c c1153dd4 dc4bb428 ef2d7d34 ef2d7d28
[ 37.458978] 7d20: c07087b8 c070857c ef2d7d54 ef2d7d38 c07070ac c07087a4 0000000b dc4bb454
[ 37.459007] 7d40: dc4bb420 c1004d88 ef2d7da4 ef2d7d58 c0703800 c0706fdc 00000002 ef2aa878
[ 37.459035] 7d60: ef2d7d84 ef2d7d70 c07964ac c0703a08 00000002 8aea40ae ef2d7da4 ef2aa800
[ 37.459064] 7d80: 00000001 00000000 ef8f6000 dc4bb400 dc4bb200 00000000 ef2d7dcc ef2d7da8
[ 37.459093] 7da0: c078ed5c c07036ac 00000004 ef2aa800 ef2aa878 ef2aa8ac dc4ba800 dc4bb200
[ 37.459121] 7dc0: ef2d7e04 ef2d7dd0 c07854f8 c078ecb8 ef2d7dec ef2d7de0 c09c910c 00000004
[ 37.459150] 7de0: ef2aa400 ef2aa478 ef2aa4ac ef23d400 dc4ba000 00000000 ef2d7e3c ef2d7e08
[ 37.459179] 7e00: c078567c c0785480 eff214c0 ef2d8080 c1004d88 00000001 ef23d200 ef23b400
[ 37.459207] 7e20: eff25f00 c1004d88 ef23d304 00000000 ef2d7e5c ef2d7e40 c0785714 c0785480
[ 37.459236] 7e40: ffffffed ef23b400 ef23d020 ef23d300 ef2d7efc ef2d7e60 c0786e38 c07856c4
[ 37.459265] 7e60: ef2d7eb4 ef2d7e70 c024d1d8 c0e9bad8 c09ce5b4 eff21040 eff24300 ef8f6180
[ 37.459293] 7e80: 40000013 00000000 ef2d7eb4 ef23d020 c0305a7c c0306c80 40000013 c09ce410
[ 37.459322] 7ea0: ef8f61c0 eff21040 ef23b400 00000000 ef23b4ac c0e9bad8 ef23d000 ef23d200
[ 37.459351] 7ec0: eff25f00 00000000 ef23d304 8aea40ae ef2d7efc ef2c0580 ef23d300 eff21040
[ 37.459379] 7ee0: eff25f00 00000000 ef23d304 00000000 ef2d7f34 ef2d7f00 c023e028 c0786aa0
[ 37.459408] 7f00: 40000093 eff21040 eff21040 eff21040 ef2c0594 eff21040 eff21058 c1003d00
[ 37.459437] 7f20: 00000008 ef2c0580 ef2d7f7c ef2d7f38 c023e36c c023dec4 ef2d7f5c ef2d7f48
[ 37.459465] 7f40: c09ce5b4 c1003d00 c1096816 ef2d6038 ef2d7f7c ef2c28c0 ef2c2680 00000000
[ 37.459494] 7f60: ef2c0580 c023e310 ef2c28dc ef911e74 ef2d7fac ef2d7f80 c02446a0 c023e31c
[ 37.459523] 7f80: c02043d8 ef2c2680 c0244568 00000000 00000000 00000000 00000000 00000000
[ 37.459551] 7fa0: 00000000 ef2d7fb0 c02010ac c0244574 00000000 00000000 00000000 00000000
[ 37.459579] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.459608] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 37.459677] [<bf95b1fc>] (dw2102_disconnect [dvb_usb_dw2102]) from [<c07916e8>] (usb_unbind_interface+0x84/0x26c)
[ 37.459722] [<c07916e8>] (usb_unbind_interface) from [<c07086f8>] (device_release_driver_internal+0x188/0x228)
[ 37.459762] [<c07086f8>] (device_release_driver_internal) from [<c07087b8>] (device_release_driver+0x20/0x24)
[ 37.459800] [<c07087b8>] (device_release_driver) from [<c07070ac>] (bus_remove_device+0xdc/0x108)
[ 37.459836] [<c07070ac>] (bus_remove_device) from [<c0703800>] (device_del+0x160/0x35c)
[ 37.459870] [<c0703800>] (device_del) from [<c078ed5c>] (usb_disable_device+0xb0/0x1e0)
[ 37.459905] [<c078ed5c>] (usb_disable_device) from [<c07854f8>] (usb_disconnect+0x84/0x244)
[ 37.459942] [<c07854f8>] (usb_disconnect) from [<c078567c>] (usb_disconnect+0x208/0x244)
[ 37.459978] [<c078567c>] (usb_disconnect) from [<c0785714>] (hub_quiesce+0x5c/0xa0)
[ 37.460013] [<c0785714>] (hub_quiesce) from [<c0786e38>] (hub_event+0x3a4/0x11d8)
[ 37.460051] [<c0786e38>] (hub_event) from [<c023e028>] (process_one_work+0x170/0x458)
[ 37.460085] [<c023e028>] (process_one_work) from [<c023e36c>] (worker_thread+0x5c/0x5a4)
[ 37.460119] [<c023e36c>] (worker_thread) from [<c02446a0>] (kthread+0x138/0x168)
[ 37.460151] [<c02446a0>] (kthread) from [<c02010ac>] (ret_from_fork+0x14/0x28)
[ 37.460177] Exception stack(0xef2d7fb0 to 0xef2d7ff8)
[ 37.460199] 7fa0: 00000000 00000000 00000000 00000000
[ 37.460228] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.460255] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 37.460282] Code: e5903074 e1a05000 e2833a01 e5936bb8 (e596404c)
[ 37.460310] ---[ end trace 4940516b154503e7 ]---
[ 37.479638] cx24116_firmware_ondemand: Waiting for firmware upload (dvb-fe-cx24116.fw)...
[ 37.480160] cx24116_firmware_ondemand: Waiting for firmware upload(2)...
[ 39.731605] cx24116_cmd_execute() Firmware not responding
[ 39.731631] cx24116_firmware_ondemand: Writing firmware to device failed
[ 39.731669] cx24116_firmware_ondemand: Firmware upload failed
[ 39.731687] cx24116_cmd_execute(): Unable initialise the firmware
[ 39.831991] cx24116_firmware_ondemand: Waiting for firmware upload (dvb-fe-cx24116.fw)...
[ 39.832113] cx24116_firmware_ondemand: Waiting for firmware upload(2)...
[ 42.081605] cx24116_cmd_execute() Firmware not responding
[ 42.081631] cx24116_firmware_ondemand: Writing firmware to device failed
[ 42.081669] cx24116_firmware_ondemand: Firmware upload failed
[ 42.081687] cx24116_cmd_execute(): Unable initialise the firmware
[ 45.212342] cx24116_firmware_ondemand: Waiting for firmware upload (dvb-fe-cx24116.fw)...
[ 45.212469] cx24116_firmware_ondemand: Waiting for firmware upload(2)...
[ 47.461603] cx24116_cmd_execute() Firmware not responding
[ 47.461630] cx24116_firmware_ondemand: Writing firmware to device failed
[ 47.461668] cx24116_firmware_ondemand: Firmware upload failed
[ 47.461687] cx24116_cmd_execute(): Unable initialise the firmware
[ 53.552347] cx24116_firmware_ondemand: Waiting for firmware upload (dvb-fe-cx24116.fw)...
[ 53.552501] cx24116_firmware_ondemand: Waiting for firmware upload(2)...
[ 55.801603] cx24116_cmd_execute() Firmware not responding
[ 55.801629] cx24116_firmware_ondemand: Writing firmware to device failed
[ 55.801666] cx24116_firmware_ondemand: Firmware upload failed
[ 55.801685] cx24116_cmd_execute(): Unable initialise the firmware
[ 60.892417] cx24116_firmware_ondemand: Waiting for firmware upload (dvb-fe-cx24116.fw)...
[ 60.892572] cx24116_firmware_ondemand: Waiting for firmware upload(2)...
[ 63.141604] cx24116_cmd_execute() Firmware not responding
[ 63.141631] cx24116_firmware_ondemand: Writing firmware to device failed
[ 63.141669] cx24116_firmware_ondemand: Firmware upload failed
[ 63.141687] cx24116_cmd_execute(): Unable initialise the firmware
[ 68.232398] cx24116_firmware_ondemand: Waiting for firmware upload (dvb-fe-cx24116.fw)...
[ 68.232547] cx24116_firmware_ondemand: Waiting for firmware upload(2)...
[ 70.481603] cx24116_cmd_execute() Firmware not responding
[ 70.481628] cx24116_firmware_ondemand: Writing firmware to device failed
[ 70.481666] cx24116_firmware_ondemand: Firmware upload failed
[ 70.481685] cx24116_cmd_execute(): Unable initialise the firmware
[ 76.532440] cx24116_firmware_ondemand: Waiting for firmware upload (dvb-fe-cx24116.fw)...
[ 76.532598] cx24116_firmware_ondemand: Waiting for firmware upload(2)...
[ 78.791604] cx24116_cmd_execute() Firmware not responding
[ 78.791630] cx24116_firmware_ondemand: Writing firmware to device failed
[ 78.791671] cx24116_firmware_ondemand: Firmware upload failed
[ 78.791690] cx24116_cmd_execute(): Unable initialise the firmware
[ 83.922615] cx24116_firmware_ondemand: Waiting for firmware upload (dvb-fe-cx24116.fw)...
[ 83.922736] cx24116_firmware_ondemand: Waiting for firmware upload(2)...
