I'm not sure should I post this here or in the noob section, but I have serious problems with a project I'm working on. I'm trying to connect a simple 3kg load cell (4 wire type) to my RPi3.
The cell came with that simple green hx711 controller board with 8 soldering points. B+, B-,A+, A-. E+ and E-. On the other side, there are GND, DT. SCK, VCC.
I was using this tutorial (https://tutorials-raspberrypi.com/digit ... sor-hx711/) to solder everything together, and a friend who's in charge of the software part got some inconsistent readings. The scale had an accuracy level of +/-10% which is a lot for a 3 kg scale. Then I found a simple hack to connect pin 15 on the hx chip to VCC, rising the sample rate. It was still very un-accurate.
I've decided to get that brown , shielded HX711 board, but that little bugger has different markings on it: OUT+, A+, A-, GND, B+, B-. I', pretty certain that the OUT+ corresponds to E+, and GND to E-. so I've connected it that way.
The other side is also different: VCC, DO/RX, CK/TX, GND. I have connected the VCC to +5V, and GND to GND on the Rpi,
I believed that the DO equals the DT pin, and the SCK equals to CK pin.
The Rpi doesn't see the scale. As it's not connected. Then I went on and about googling for possible pin connections, and found several:
DO/Rx should be connected to GPIO28 ...which equals to DT and GPIO9
CK/Rx goes to GPIO30... and that should correspond to SCK and GPIO11
that didn't work either. GPIO 28 and 30 aren't marked on the pin layout..
I thought that the E+ or OUT+ equals to a +5V source (if the VCC pin is connected to +5V obvs), but my voltmeter doesn't measure anything. On some posts I found that the red wire from the load cell should be connected to the VCC (+5V). Tried that as well.
found another one with DO and CK connected to pins 5 and 6 if counted from the USB ports (left row, closer to the HDMI port, haven't had the time to test that version yet)
Nothing works. In the meantime, I managed to damage my SD card, loosing everything, then I corrupted a spare one I had because I stopped the IMG writing.. and finally got the 3rd working again.
To get to the point....
which is the correct wiring diagram for the brown (red?) HX 711 amplifier circuit, for the RPi3? what pin (either by official pin layout, or basic counting method) should each of the hx 711 points be connected? Same with the cell.. if the green wire is A-, and the white A+, where do I connect the red one? Out+ or the +5V (VCC pin on the other side)
you can even mark it out on the pin layout picture
https://www.jameco.com/Jameco/workshop/ ... e_fig2.jpg
please help me, because this is really frustrating.
I'm using a fivr programmer from Pakistan, so both the time and mileage difference aren't helping matters...
