Is it possible to set audio to work on the second hdmi port (the one closest to the 3.5mm headphone jack) when that is the only port an hdmi cable is plugged into? I believe it is called hdmi1 or hdmi 1?
The micro to hdmi adapter I have is to fat to fit comfortably next to the power cable, so I've been using the second port.
Video and audio works when plugged into the first port on both my TV and my monitor, but it puts way too much stress on the connectors.
Video works on my TV and my monitor using the second HDMI port, but I can't get audio. Is there a setting I can change to force audio out over the second HDMI port, or should I just buy a better fitting cable?
Thank you.
