WCHD
Arch Linux ARM "startx" failing to work
Sun Jan 19, 2020 4:33 am
I was casually setting up 4 systems from PINN (a RPi tool), on my RPi 3 Model B
Suddenly, while I was almost finished setting Arch Linux ARM (arch2 port for RPi), "startx" returned error (1) with more actions from Xinit. I remember a line that said "Connection Refused".
I was messing with this for about 5 hours today, into the night. I cannot attach the log file, since I am new to Arch Linux (I am used to Debian, however)
Help?
Re: Arch Linux ARM "startx" failing to work
Sun Jan 19, 2020 8:41 am
Help?
ArchLinuxArm is a command line Linux Operating System, by default it has no desktop environment.
Therefore your choices are to install a desktop environment or use Manjaro Linux.
RPi 4B 4GB (SSD Boot)..
geev03
Sun Jan 19, 2020 10:54 am
Help?
... install a desktop environment or use Manjaro Linux.
Manjaro Linux is more useful on a 4GB RAM rPi4
jojopi
Sun Jan 19, 2020 11:04 am
Is it possible you simply ran out of disk space?
Otherwise, you are going to have to pay more attention to the error messages, and probably also check the Xorg log. I do not know if that would be /var/log/Xorg.0.log, or ~/.local/share/xorg/Xorg.0.log, or something else in Arch.
GlowInTheDark
Sun Jan 19, 2020 12:12 pm
Also, you need to identify if this was working and then stopped working vs. it never working at all.
Other posters have suggested the possibility that X was never installed on the system at all, which is consistent with a barebones Arch Linux Arm install. But in that case, typing "startx" would return a "Command not found" type error. That is not what has been reported in this thread.
Anyway, as noted, if it is in the "was working but stopped working" category, then, yes, running out of disk space seems to be the #1 cause.
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
Sun Jan 19, 2020 1:21 pm
The xinit program allows a user to manually start an Xorg display server
https://wiki.archlinux.org/index.php/Xinit
WCHD
Sun Jan 19, 2020 11:30 pm
I know about it being command-line, I saw people get desktop on it, and Manjaro is not of my preference.
I was installing Cinnamon dwm, is that the problem? Does Cinnamon not work on RPi?
WCHD
Sun Jan 19, 2020 11:31 pm
Help?
I clearly said RPi 3 model B.
WCHD
Sun Jan 19, 2020 11:32 pm
Can't attach xorg log, new to arch, sorry. I do know, however, that error (1) occurred. It said "screen not found", I was using a Samsung TV as my monitor. Am I not understanding something about ee1?
cjan
Sun Jan 19, 2020 11:56 pm
did you try any display manager?
Return to “Arch”
