Skelingaton
Getting Permission to Edit Config.txt
Fri Jan 17, 2020 1:02 am
I think I'm finally narrowing down my display problem on my Pi 4b but I've run into another issue. I found the config.txt file in my Pi boot directory but it won't let me save changes to it. I've read that you need to use a sudo command to access programs as the superuser but I don't know how to make this work for the config.txt file.
I've typed just Sudo into the command box and then tried opening the config file editing it and then saving but it still won't let me. I've also tried typing sudo boot/config.txt but it says command not found. It does the same thing when just typing just boot/config.txt. Also, when a line says to uncomment in the config.txt file does it mean to delete it out of there or just set the value to 0?
jahboater
Re: Getting Permission to Edit Config.txt
Fri Jan 17, 2020 1:11 am
You need to use a text editor to alter a file. Examples are nano, vi, emacs etc. I suggest trying nano to start with.
Practice changing a local file in your home directory.
nano file
To edit config.txt you will need:
nano /boot/config.txt
This however will fail because you do not have permission to alter system configuration files.
The sudo command temporarily gives you that permission:
sudo nano /boot/config.txt
It means remove the # character at the start of the line.
Skelingaton
Fri Jan 17, 2020 1:43 am
Well I figured out how to edit the text. Unfortunately changing the settings did not solve my problem of the video not outputting to my main TV. Really not sure what to do now.
Botspot
Fri Jan 17, 2020 2:16 am
You risk being banned for a week if you post duplicate topics. Here is the duplicate topic.
I suggest you delete one of them to avoid moderator action.
Want to make your own Raspbian image?
  • Hard way: Mess with confusing terminal commands.
  • Easy way: Let Pi-Power-Tools do it all for you!
Boot your image in a VM, Flash from the Internet at top speed, Mount (to drop files in), Edit partitions, Shrink/Expand, Repair, and more. Enjoy! :)
https://github.com/Botspot/Pi-Power-Tools
Skelingaton
Fri Jan 17, 2020 2:22 am
If I knew how I would.
Botspot
Fri Jan 17, 2020 2:35 am
No problem. I was banned for a week once for dupli-posting, not fun!
Just push the report button on the top post, and say you want the topic deleted.
Fri Jan 17, 2020 7:32 am
You won't get banned for a duplicate post, just told not to do it again. Banning is for something more serious.
You can't delete posts one made (and replied to), but you can report them and ask the moderators to do it for you. Sometimes the duplicate gets locked along with a warning that duplicates are not allowed. This is to inform future posters that it is not right to post duplicates.
Unreadable squiggle
Botspot
Fri Jan 17, 2020 1:14 pm
I posted a duplicate, and got banned for a week. Never saw a warning, never saw it coming. Just basing off what I have experienced, and trying to keep users from having to learn the hard way too.
Fri Jan 17, 2020 1:17 pm
That is not the norm and I suspect you had done something else to justify a short ban. I have no idea what that might have been. The mods may like to comment.
Unreadable squiggle
GlowInTheDark
Fri Jan 17, 2020 1:24 pm
Or he just caught one of the mods on a bad day.
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
jahboater
Fri Jan 17, 2020 3:15 pm
The forum rules are simple:
https://www.raspberrypi.org/forums/view ... 63&t=15137
A simple, unintentional, mistake by a new user is not reason for a ban.
Must be something else.
Back to topic, or I'll get banned :)
