EdEstes
Node: Issue installing node-imagemagick-native
Thu Jan 16, 2020 6:40 pm
Greetings.
I have ImageMagick installed via:
sudo apt-get install imagemagick
When I attempt to install the node-imagemagick-native package:
npm install imagemagick-native
I get the following error:
> [email protected] install /home/pi/server/node_modules/imagemagick-native
> node-gyp rebuild
/bin/sh: 1: Magick++-config: not found
gyp: Call to 'Magick++-config --ldflags --libs' returned exit status 127 while in binding.gyp. while trying to load binding.gyp
According to the installation notes:
Make sure you can find Magick++-config in your PATH. Packages on some newer distributions, such as Ubuntu 16.04, might be missing a link into /usr/bin. If that is the case, do this.
sudo ln -s `ls /usr/lib/\`uname -p\`-linux-gnu/ImageMagick-*/bin-Q16/Magick++-config | head -n 1` /usr/local/bin/
but this fails when I run the command. I'm not savvy with raspbian (or any flavor of unix) so I'm not sure how to troubleshoot/resolve this issue.
Thanks!
--Ed
