croft
formated usb thum drive
Thu Jan 16, 2020 4:06 pm
hi
formatted thum drivw is not seen
how do i make it be seen
thanks
croft
B.Goode
Re: formated usb thum drive
Thu Jan 16, 2020 4:20 pm
hi
thanks
croft
Presumably a usb-connected mass storage device?
What model of Raspberry Pi board is involved?
What Operating System is it running?
How was the usb device 'formatted'? What type of filesystem does it now contain?
croft
Thu Jan 16, 2020 4:23 pm
raspberry pi 4 buster
formated g parted
fat32 ntfs no luck fat 32
thanks
B.Goode
Thu Jan 16, 2020 5:06 pm
formated g parted
thanks
Do you have a reliable, preferably 'official', power supply for your RPi4b?
Since you have mentioned two "Microsoft" filesystems, perhaps you intend to use this thumb drive to transfer data to some sort of Windows system?
Have you tried formatting the storage device on the Windows system it will be used with?
Maybe the thumb drive device is faulty? Have you checked it with any other systems to confirm it works?
croft
Thu Jan 16, 2020 5:08 pm
pi psu for pi 4
will try
thanks
croft
Thu Jan 16, 2020 5:31 pm
yes will work on win box
Technocolour
Thu Jan 16, 2020 5:49 pm
I remember you asking a question before regarding backfeeding protection on the Pi's USB ports (yes?), did you connect something that could have backfed the Pi?
croft
Thu Jan 16, 2020 5:52 pm
no
i was thinking of using a externally powered hd
thanks
B.Goode
Thu Jan 16, 2020 5:58 pm
On the Raspberry Pi running Raspbian Buster use the following information gathering commands before plugging in the external mass storage.
lsusb
df -h
dmesg
Then plug in the drive and repeat the same commands. What difference, if any, do you see in the output?
croft
Thu Jan 16, 2020 7:38 pm
thanks i found the anser
croft
B.Goode
Thu Jan 16, 2020 8:25 pm
croft
In the spirit of these forums being a community where users help other users, could you say briefly what you found, in case it is of value to some future reader?
Russell1993
Fri Jan 17, 2020 6:28 am
He probably means the last one suggested.
